Question about RCA Audio Players & Recorders
Can you hook up a subwoofer from a RCA home stereo to a pioneer SX-205
Posted by pedrolawrence baca on
Curt Mueller
    Passionate:
    Visited the website for 10 consecutive days.
    Habit-Forming:
  • 182 Answers
Are you using the RCA or Pioneer as the receiver? It also depends on the outputs in back. Does it have a main in and pre out? You can hook up a sub woofer to a old receiver but not all.
Posted on Dec 16, 2021
Paul Katynski
    Master:
  • 556 Answers
Yes no problem
How do I hook up a powered subwoofer to a pioneer sx-316?
Many subwoofers accept both line level (RCA jacks) and amplified inputs (+ and - speaker terminals). The Pioneer SX-316 does not offer line level output, only amplified outputs via the PURPLE + and - speaker terminals. This means that in order to use any subwoofer with an SX-316, the sub woofer will need to accept a + and - speaker wire connections for input Your manual speaker connections are on page 11 of the manual which can be found here: http://www.manualslib.com/manual/260358/Pioneer-Sx-316-S.html#manual
Starting at the rear of the SX-316; run a speaker wire from the PURPLE + and - terminal (SUBWOOFER) to the + and - speaker input terminals on the subwoofer. See your subwoofer manual or experiment (at your own risk) with connecting the speaker wire from the SX-316 to the subwoofer's + and - LEFT only, RIGHT only or BOTH left and right speaker inputs. Do not connect wires from the SX-316 to the speaker OUTPUT terminals of your subwoofer.
Finally, adjust any variable low pass filter knob or setting on the subwoofer to the lowest frequency that your main speakers are capable of producing. If you're not sure what that value is, try setting the subwoofer to 100Hz and judge how it blends with the main speakers. If it seems a little too bass heavy and thick then reduce the setting to 80Hz. On the other hand, if the sound seems to be slightly thin and lacking weight, try increasing the setting to 120Hz. By careful listening and a bit of patience you will be able to get the sound to seem balanced and well blended.
2helpful
2answers
Owner manual for pioneer sx 316s
You may download a copy of the operating instructions here.
I have a Pioneer SX-980 stereo receiver. I need to how to hook up speakers to it. Thank You
CLICK HERE
When you register for a free account - you can download the service and owner's manual.
Thanks!
Can i hook up an ipod to my pioneer stereo receiver SX-251R?
yes get an 1/8 headphone to rca cord at radio shack or other electronics retailer. use any input except phono
2answers
Blown Fuse / SX - 205 / Pioneer reciever
Check the area where the fuse was...it's usually marked on the board or next to the fuse holder. Check the size also, 2 types 5x20mm or 1/4x1 1/4 in. Usually slow blow.
1helpful
Pioneer Receiver SX-205 flashing ''overload''? Nothing in owner's manual troubleshooting chart.
usually it is a technical indication of the output being shorted. disconnect all speaker wires and try again. still blinking?
4helpful
I have a Pioneer SX 251R and a PD M501
How about a Pioneer CT-W302R stereo double cassette deck ?
I have a unit in very good condition for sale.
[email protected]
2answers
Subwoofer instalation
Even if your JVC doesn't have outputs for a subwoofer you can hook it up with the a speaker wire to RCA converter. You just spice your rear speaker wires to this device then connect RCA's to your amp. I've used them before... works great. http://cgi.ebay.com/ebaymotors/Speaker-to-RCA-Line-Level-Converter-Adjustable-High-Low_W0QQitemZ130143832174QQihZ003QQcategoryZ38636QQcmdZViewItem
Top RCA Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
