Sewing Machines Logo
S
Saho Posted on Dec 16, 2021
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I need a repair manual for a 1471 Pfaff please..
Paul Katynski
Level 3:
Master:
  • Master 575 Answers
  • Posted on Dec 16, 2021
Paul Katynski
Master
Level 3:
Master:
Answers
575
Questions
Helped
130551
Points
1806
Https://www.eserviceinfo.com/index.php?what=search2&searchstring=Pfaff%20Creative%201471
PFAFF creative 1471-sewing foot?
It's not the foot, it is the 'Feed Dogs', the teeth in the base that pull the material UNDER the foot. The most likely reason is that you have lowered them too much, or set it to 'embroidery'.
Page 50
https://www.manualslib.com/manual/969570/Pfaff-Creative-1471.html?page=50&term=Dropping+The+Feed+Dog&selected=1#manual
ManualsLib https://www.manualslib.com > ... > Creative 1471
View and Download Pfaff Creative 1471 instruction book online. Creative 1471 sewing machine pdf manual download.
Pfaff creative 1471 user manual (English - 76 pages)
Manuals.ca https://www.manuals.ca > Sewing machines > Pfaff
User manual. View the manual for the Pfaff creative 1471 here, for free. This manual comes under the category Sewing machines and has been rated by 5 people ...
My Pfaff 1471 keeps spinning when I'm winding bobbin. It won't lock needle from going up and down
You probably didn't disengage the sewing machine mechanism. Hold the hand wheel steady so that it will not move with one hand. Use your other hand to rotate the knob in the center of the hand wheel towards you. When the unit is properly disengaged, the motor can't move the needle bar. When done winding the bobbin, you need to hold the hand wheel and then turn the knob away from you. See page 9 of the manual for the Creative 1471. Pfaff has the manual on the product page: http://www.pfaff.com/en-US/Machines/creative-1471 . The current link to the manual is http://www.pfaff.com/SiteMedia/PFAFF/Products/Machines/Support-manuals/creative1471-manual-EN.pdf .
I hope this helps.
1helpful
The flywhee on my pfaff 1471 seems to have disengaged after unsuccessfully winding a bobbin. The motor goes but the needle does not go. What to do?
Did you turn the knob inside the hand wheel backwards while holding the wheel itself? If that knob is in the correct position, did you hear it snap into place when you rotated the hand wheel towards yourself? Does the needle bar move up and down when you rotate the hand wheel?
I suspect that the needle bar is still disengaged from the motor mechanism. The manual is available from Pfaff on the creative 1471 page: http://www.pfaff.com/en-US/Machines/creative-1471 . The direct link to the manual is http://www.pfaff.com/SiteMedia/PFAFF/Products/Machines/Support-manuals/creative1471-manual-EN.pdf . See page 13 of the PDF for the picture of the direction and position of the knob that should be checked.
If the machine still doesn't work, it may be that the belt is bad. This connects the shaft of the motor to the mechanism that runs the needle bar. You can find a parts list for the 1471 here: https://www.universalsewing.com/tek9.asp?pg=parts_pfaff . Scroll down to find the various 1471 diagrams. The belts are probably available at most Pfaff or other sewing machine dealers. This page, https://www.sewingpartsonline.com/pfaff-1471-sewing-machine-parts.aspx , is one source. You want the motor belt.
I hope this helps.
Pfaff 1471 threading instructions
Hello Patricia P. Thomas
Download a free Pfaff 1471 Manual here
https://www.manualowl.com/m/Pfaff/creative-1471/Manual/333543
The threading instructions are quite simple to follow.
Please let me know how this works out for you.
Happy Stitching
1helpful
2answers
3answers
Timing off on Pfaff 1471
I assume that you are attempting to time the hook. The hook timing should be about 2 to 2.3 mm rise in the needle bar from bottom dead center.
Top PfaFF Sewing Machines Experts
ExpressFiX
ExpressFiX
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
