How do i install my WIRELESS G ROUTER 802.11G/2.4GHZ DIR-300 without the cd because i lost mine i still have the router and all the appliances
First connect your router to computer with ethernet cable.
Then you can access it with following link
http://192.168.1.1
or
http://192.168.0.1
type user as "admin" and password as "admin" or blank or "password"
then go to wi fi enable wireless security set your WEP code it is your password to connect wi fi network
If you want ip addresses by router to your computers enable DHCP.
Then save and restart computer..
Let me know if you need more assistanse.
Thanks
Download from the web site and install,try this link should be what your looking for
http://www.dlink.com.ph/products/support.asp?sec=&pid=602#firmware
SOURCE: Dir-655 works with XP and Mac which can connect
Go to 192.168.0.1 and login. Then go for the 'Setup' tab on the top and look for the 'Wireless Settings' tab on the right.
You can now automaticly setup your WLAN connection and afterwards you can go to the 'Manual Wireless Network Setup'. Over there you can change the 802.11 mode.
Go for the last one that uses n,g and b and you will be sure your computer can connect :)
SOURCE: low signal in the basement
maybe you should try to purchase a better wireless adapter,like dlink dwa-110
