Question about Mitsubishi WD-62525 62" Rear Projection HDTV
Red lamp light on Mitsubishi DLP 65" WD-C657
I bought this TV from Costco a couple years ago. Today I noticed the lamp light was RED while the TV was turned off. When I pressed the power button the green power light displayed and I heard "white noise" coming from the TV. The picture did not display. I assume it is a burnt out lamp since:
A: the lamps are consumable and I have been using the same one for about two years, never replaced.
B: The lamp light is illuminated RED when the TV is off.
Before I order a new lamp I was wondering if someone could post a reply and let me know if this is a difinitive solution =) Thank you very much.
ladywinn
  • Mitsubishi Master
  • 5,138 Answers
Lamp is always First to go unless power surge gets it Call Mats for Lamp 1-800-628-1118 or Find one on E-Bay got mine there for 85.00 free shipping.
Posted on Sep 21, 2009
What does the yellow blinking light mean on Mitsubishi WD65837
Here is a whole list for you :
Mitsubishi Blinking Codes :
Constant Green - TV is Powered On
Constant Red - Lamp Failure
Constant Yellow - DMD temp is very high
Blinking Yellow - Lamp cover is open
1 Red Blink, 6 Yellow Blinks - Color Wheel Failure
3 Red Blinks, 4 Yellow Blinks - Lamp Failure
3 Red Blinks, 6 Yellow Blinks - Exhaust Fan Not Working
3 Red Blinks, 7 Yellow Blinks - DMD Fan is not rotating
5 Red Blinks, 7 Yellow Blinks - Ballast Problem
6 Red Blinks, 6 Yellow Blinks - Lamp Missing, Bad Cable between lamp and ballast
And the Lamp cover must be here somewhere in your TV :
For more you can refer to the below link :
Mitsubishi DLP TV Blinking Code Errors Explained Overview of Each...
Jul 07, 2014 | Mitsubishi WD 65837 65 in. HDTV
How to change tv lamp mitsubishi wd-c657
Read page 61 and 62, this s is the official Mitsubishi Owners Manual for you TV
http://static.highspeedbackbone.net/pdf/Mitsubishi-WD-C657-Manual.pdf
Jan 27, 2011 | Mitsubishi WD-C657 65" HDTV
When i press power button green light comes on and then red light blinks 2 but the tv does not turn on
Question title shows it is Mitsubishi WD-65737 tv.
When did you replaced lamp in tv?
If lamp has not been replaced in last 2-3 years, please check lamp as it seems dead, that is why tv does not turn On.
Aug 26, 2010 | Mitsubishi WD65737 65" DLP TV
I have a Mitsubishi DLP WD-57734 and white spots just started appearing I have owned the TV for 2 years and only one person in family uses it and not video games have replaced the lamp on time
The projection engine have problems,it the cause.Two years tv shouldn't have this problems already.Call talk to mitsubishi,might get some help the cost of the repair.
Jul 03, 2010 | Mitsubishi WD-57734 57" HDTV
My 62 inch dlp tv came on and was working then with out any noise or notice the picture went to black and a steady red light came on under the word "lamp". We looked at the bulb and it does not look burned...
The tv lamp was replaced when? The tv on about 4 or 5 hours a day right?The lamp was replaced about a year or a year an a half ago?The projection lamp is dead,the life span is over.Must replaced with a new lamp.
Jul 01, 2010 | Mitsubishi WD-62525 62" Rear Projection...
Powers off and the lamp light goes red
The lamp will sometimes not turn dark before they start to go out. The life on these lamps are usually a year to a year and a half but, depending on when you purchased it in 2008 it may still be in warranty the lamp has 1 year on it.
Jul 28, 2009 | Mitsubishi WD-65732 65" Projection HDTV
Mitsubishi 65" DLP HDTV, Status light is red, no picture
Check your lamp; it may have blown. Sound, no picture and a red light are classis signs a lamp has failed.
Feb 02, 2009 | Mitsubishi WD-62528 62 in. LCD Television
Mitsubishi WD-62525 62" Rear Projection HDTV Logo
834 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Todd Hill
Todd Hill
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
