Televison & Video Logo
Question about Samsung Televison & Video
Samsung Tv model QN75Q70TAFXZA stopped working
My Samsung Tv model QN75Q70TAFXZA stopped working while watching a local station. Screen turned black and flickers blue at times. Not the entire screen only a portion. The red standby light flashes and the tv powers on an off continuously. If I power the tv on and off repeatedly I will get a couple if words on the audio but it stops immediately. I tried several reboot options but none worked. Can you help? Don't know what parts I might need...Thank you..
Posted by Brian Arlotta on
ADMIN Eric
    Top Expert:
  • Samsung Master
  • 37,876 Answers
Count the flash routing, that is the error code and t can point you in the right direction.
Posted on Dec 08, 2021
Testimonial: "Thank you I'll try that."
  • 1 more comment
  • Brian Arlotta
    Brian Arlotta Dec 08, 2021
    Is there someplace I can find an error code sheet?
  • ADMIN Eric
    ADMIN Eric Dec 08, 2021
    If you google "panasonic blink codes", that should give you the answer.
  • Brian Arlotta
    Brian Arlotta Dec 09, 2021
    Can't find anything for codes on my Samsung
Samsung 6 series tv blackscreened and reset doesnt work, what parts need replacement?
Hi Doug, you already diagnosed your set when you said it flickered like a dying light bulb, your LED backlights have failed and need replacing, you should be able to get parts from shopjimmy, stay away from ebay for parts
1helpful
Not Solved 9/17/18 A 9 yr old 55 LG LCD tv I need help with. Model 55LH55-UA w/ black screen exhibiting the following: -turning on tv by remote or on the side, blue ON light comes on, screen is black.
Sounds like you have LED backlights that are going bad and the strips need replacing, its not a real easy job but if you watch some youtube vids they show how to do it.
I have a 50" Samsung tv. The tv turns on and the screen comes on, then within 1 minute the screen goes black. I can still hear sound.
Samsung HL-R5087W TV screen goes blank -tv/sound on - Forums ...
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - About a month ago, the at various times the tv screen would go blankeven though the tv ... Try turning off the cable/sat box when the happens. ... In reply to: Samsung SP50L7HX DLP TV linked to Sky HD box - same problem .... on it comesback to normal. however, once it went off again (Black Screen) after only 2-3 minutes. ln-t4069f picture problem lcd warmup - Forums - CNET
Jun 11, 2015
Samsung LCD TV LN-T5265F Black Screen Diagnosis Help ...
Jun 11, 2015
More results from www.cnet.com
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
https://www.youtube.com/watch?v=kFdVi2ejfzA
May 8, 2014 - Uploaded by ShopJimmy.com
TV Repair Help for a TV With a Black No Image on the Screen ...Sign in to add this video to a playlist. ... LCD & LED TV Repair - No Image & Blank Black Screen Flashlight ... Easiest TV repair - How to Fix Power [TV turns off, freezes, or won't ... 1:26.Samsung LED TV Blank Screen & No Backlights Basic ...
Samsung TV screen goes black w/ audio still playing ...
? 1:49
https://www.youtube.com/watch?v=L9cjcsysdW4
Sep 11, 2012 - Uploaded by Roberto Ramos
TV screen begins to flicker then screen turns black while the audio continues to heard. I'm unable to see the TV Menu options when screen turns off. ... After turning the TV OFF then back ON again, the screen will flicker and then ... 1:26. Samsung LEDTV Repair - T-Con Board Replacement - No Picture on ...
Need fixs how do i make it stop flickering?
How do i stop my vizio from flickering? - YouTube
? 2:18
https://www.youtube.com/watch?v=RD2PwPFpbrE
Jul 19, 2013 - Uploaded by colguon38
Please help me stop my TV from flickering. ... 1080p. the monitor will momentarily change resolutions. that is the "flicker" you see. unfortunately i ...
EASY How to Fix Samsung LCD TV Flashing Flickering ...
? 3:43
https://www.youtube.com/watch?v=i-jQZ-TQdgU
Jun 4, 2012 - Uploaded by Tampatec
How to Fix Samsung TV Flickering Blinks Flashing Flat Screen Picture EASY ... I have this exact make and model. .... and theflickering didn't stop. any ideas as to which JP I should cut . please help not ready to buy a new TV.
VIZIO flickering Tv screen easy fix( no money ) - YouTube
? 1:58
https://www.youtube.com/watch?v=oWSFwS3FH_c
Aug 28, 2012 - Uploaded by Bill GatesBestfriend
this might work for other tv's too. ... If your not sure you can dothis repair your self please take it to a tv repair shop. The repairshould be ...
Samsung tv has flickering lineswhile watching tv
? 3:43
Jun 4, 2012 - Uploaded by Tampatec How to Fix Samsung TV Flickering Blinks Flashing Flat Screen ... Rating is available when the video has been rented. ... sorry to bother you tampatec but i have a RCA tv it works great when it's.... My Toshiba Full HD led tv model 32PT200ZE is having issues of screen blinking/flashing and horizontal lines.
Plasma tv video
Could be the power supply inside the TV is bad. Check with your local authorized Samsung repair center. DON'T try to fix it yourself.
Screen flicker/going black
the problem is power supply replace it.
Certain channels on the tv flicker when I change channels and the screen will black out for about 3 seconds as if it's seraching for the signal. The flickering and blacking out is very intermittent. I have...
Rogers cable is using what they call "switch digital" this allows more channels to be placed on the platform they are using to give you more stations. This basically means people on the same line that you are, are not watching this station so they put that station "off" until someone tunes into it.
1helpful
Lost entire picture, sound and everything else OK
check the invertor boards resistors they power the back lights
also check for any capactors that have blown (raised tops) they look little bateries
 Grubhead
Grubhead
