You will need to connect a streaming media player to the Pioneer Elite Pro-111FD. This can be your computer (make sure to set the HDMI input to PC, if needed) or a Roku or Fire (either the stick format or the box). Set the TV to the correct HDMI input and then access Netflix on the media player.
The Ethernet port on this TV is only for use with media saved to your local network. The TV cannot directly use the Netflix app or website. See the manual for details on the Home Media Gallery Server features of the Pro-111FD. The manual is available from Pioneer on the product page: https://www.pioneerelectronics.com/PUSA/Home/Plasma/PRO-111FD . The direct link to the manual is currently https://www.pioneerelectronics.com/StaticFiles/Manuals/Home/PRO-151FD_OperatingInstructions0905.pdf .
My pioneer 5020FD Kuro tv. when I plug power to the unit, a blue light blinks 8 times pause 2 sec. and blink 8 times repeating this and if i press power button it clicks red light and makes a clicking sound and goes back to the blue light blinking again, it did this once before and the picture came on fine until i turned it off and now it just blink the blue code.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. Viewing it in "Mosaic" or "Magazine" will make surf easy. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience. Do a search by type in the brand name of the device to the search box.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating, to many popular brand TVs and other devices. Viewing it in "Mosaic" will make surf easy. http://electronicshelponline.blogspot.com/
8 times blinks denotes a cooling fan failure. If you wish to get some details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Timeslide / Flipcard, can be
selected by the drop-down list, at the top left of the display window,
will make surf easy. You can also do a
search, by type in the brand name / model number / IC used, in the
search box at the top right of the display window.
Check your power source (electrical outlet) and the power cable. If electrical outlet is ok, try using a different power cable (the cable that you plug on to the electrical outlet going to your TV set). If everything is ok but still no indicator light, call your technician there might be a problem with the TV power supply.
Since your plasma is less then a year old, I would suggest to contact the manufacturers to get it fix under warranty. If the plasma keeps shutting off by itself, that is not normal and should be repair.
Yes it is plasma
