Question about Smeg Microwave Ovens
Smeg microwave convectio/grill oven model SA987CX does not preheat
Smeg microwave convection/grill oven model SA987CX does not preheat what is the problem and how to fix it Rang smeg centre in Sydney Australia their want to book me in for service. the technician would cost me $125.00 for the Call including first 15 minutes on site plus cost for the parts additional plus additional cost past the 15 minutes. I did refuse the offer thanking them with grace.
Posted by Vincent Tizzone on
Isaac Richards
If your microwave oven doesn’t heat, you may have a problem with the high voltage diode or rectifier. This component helps provide the high voltage that powers the magnetron. The high voltage diode is located near the magnetron and the high voltage capacitor, so access will require removal of the cabinet. Disconnect the power and also discharge the high voltage capacitor to prevent an electrical shock. You can then test the diode for continuity with a multi-meter. Diodes are polarity specific and you should see low resistance with the meter leads in one direction and higher resistance when the meter leads are reversed. Most multi-meters will have a special setting for diodes or rectifiers. If the high voltage diode shows low resistance in both directions or shows no continuity at all, then it will need to be replaced. If you find the high voltage diode tests okay, then you will need to determine whether power is being supplied to the circuit. This is a high voltage circuit and further testing should only be performed by a qualified technician.
Posted on Dec 07, 2021
Ho to preheat emerson MWG9115SB microwave convection oven for baki g
it is not a convection oven only microwave and there is no preheat. refer to your owners manual.
Why does it display error 2 after five seconds?
What is the model? On this link for their brand error 2 means temperature higher than expected inside the oven or the temperature sensor is not working right.
Smeg SA987CX Installation And Operating Instructions Manual To Stop The...
In a smeg convection oven what is the pad on inside right side
Sounds like it would be the waveguide cover, but that should be covered in your owner's manual.
1helpful
My microwave is not producing any heat its runs but doesn't heat, the cooling fan still comes on. its a SMEG microwave Convection grill oven model NO:SA971C2 could it just be a fuse or something like...
usually not a fuse if other parts are running
There is only one fuse inside the unit. It may be the Magnatron, depending on its age. This would be an expensive fix. If its still under warranty I would call for a sevice before it expires
Smeg SA987CX error message E plus a high pitched continuous sound. Need to disconnect power to stop. This only seems to happen when I microwave. Does anyone know what is wrong and how to fix.
Sounds like the Magnetron in your Microwave has shorted out causing it to scream .. lol own purely none technical term .
Its actually a harmonic caused by the magnetron's anode resonating , usual fault caused by breakdown of the filaments , it is pretty much had it a new magnetron would cost almost as much as a new microwave . it may just possibly be the power supply with an oscillator fault but again that is a symptom of a serious power drain problem that also points to the mag ... sorry Regards Vortash
1helpful
I have recently been given a Smeg microwave, product No, SA987CX, but I have no instruction manual and would like to know where I can find one.
I have looked and I can't find one either. You can mail Smeg in the UK at [email protected] They may be able to point you in the right direction.
GE Microwave/Convection JVM 1090 oven won't reach temperature
You probably have a bad thermistor.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
(At that site, that part is misspelled as "thermister" for your model).
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Accessing some components for testing will require you to remove the oven from the wall.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download GE owner's manuals and installation instructions here.
Oven stop working while it was preheating to 450 degrees
Chances are the oven cavity thermostat has failed.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
Smeg fmc24x oven and grill work turntable and microwave dont
I have a simular model and I found that the circuit board has three black relays, one for the grill one for the convection and one for the microwave. I found that the microwave one wasnt working so by swaping the microwave one with the convection one I got it to work and then replaced the faulty one with a new one at a later date.
Microwave Ovens Logo
Top Smeg Microwave Ovens Experts
ray gallant
Tom Chichester
Are you a Smeg Microwave Oven Expert? Answer questions, earn points and help others
