Question about Light Office Equipment & Supplies
Empty toner light won't reset - Light Office Equipment & Supplies
Posted by Connie O'Daniel on
Mehandi Husain Suleman
  • Light Master
  • 1,654 Answers
Hi
which brand you have all the printer has a different prosier......
Posted on Dec 09, 2021
2answers
Replace new toner and displeyd mesages "chesk waste toner box". i remove waste toner box and cleaned waste toner in drum unit. no result...
the top of the waste toner container must be cleaned 100% from the toner because it should be a light sensor that has to pass through it , if its spoiled with toner the light cannot pass through it ,so i recommend you to empty the waste toner container first and wash it with water and drying it well before using it again.
1helpful
How do I reset the alert light still on to off ? after refill black toner ?
Replace the chip, or mite have a RFID chip then you need a new cartridge
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
1helpful
Brother 9460 reset toner
Like most laser printers, the toner light comes on early. This gives you time to order new toner. I find it best, since it does not stop the printer from printing, just to have a toner on hand and when your toner is empty replace it. Since this is a mesurement inside the toner cartridge its self, there is no way to reset the warning (other than replace the cartridge).
PC 921 toner light on. Replaced toner cartridge, light still on: won't function.
You see these machines needs to be kept very well.
1. the machine is not sensoring your toner.
a) need for the machine to be serviced it probably has a lot of spill toner inside.
b) toner empty sensor is not positioned properly.
b) the toner empty sensor is not functioning properly and needs to be changed.
1helpful
In samsung scx 4x21 all-in-one, fax received but not printing. "memory received" we get in display panel.
your toner is empty refill or replace it. You can continue printing when the toner is empty but the faxes recieved will not be printed till the toner empty light is reset.
1helpful
I had new tonner cartridge installed and it still says tonner life ended
The toner cartridge in this machine has a gear assembly that resetting the "toner empty" light, it is build in a way that after resetting the printer it "disabling" the gear, so no second reset is possible. If you install the new cartridge previously and took it out it already run the reset cycle and will not be able to reset the printer even if it full with toner. Some time the gear reset system will not reset even if it is new. If you reset the gear and the light comes back your cartridge is empty.
You can open the gear cover on the toner cartridge and reset the gear to the original position it is not a big deal, but don't hold me liable to your technical ability. The reset gear is the most right gear behind the "window" on the right side of the cover, when you are holding the cartridge with the gear housing in front of you. Good luck.
2answers
Brother HL-5250DN Laser Printer TONER LIGHT ON & NO PRIN PAGE
When the toner light is on this means the toner is empty and needs to be replaced before it can print again. Replace the toner and you will be able to print again.
1helpful
About Nashuatec Aficio SP 3200SF question
You could try going into the sp modes and check sp 5052-1 this is for independent toner check if the toner cartridge was checked by the copier as empty and you refilled it the machines check of the chip still senses it empty by turning this off it could reset it for you .. I have had some mixed results sometimes it works only occasional failure.. Hope it helps Good Luck A
3helpful
2answers
Muratec mfx 1600 drum replaced alarm will not reset
Ignoring the Toner Empty Message
When the toner cartridge is empty, the machine shows a “Toner Empty”
message and stops printing.
You can set the machine to ignore the message when it displays and to
continue printing the pages.
1 Press Menu until “Machine Setup” appears on the display.
2 Press the scroll button (�� or ��) until “Ignore Toner” appears on the
bottom line and press Enter.
3 Press the Scroll button (�� or ��) to select “On” or “Off.”
Select “On” to ignore the Toner Empty message.
Select “Off” to stop printing when the message appears. This is the
default setting.
4 Press Enter to save the selection.
9helpful
5answers
Toner empty error while toner is not empty, cannot print any document, system data can be print through the printer
toner empty replace toner with without reset chip
i want window file printer start without reset chip run printer
i am all ready use ml1640,ml2245 printer file use
thanks
vijay
Top Light Office Equipment & Supplies Experts
Arnie Burke
Arnie Burke
ADMIN Canada
ADMIN Canada
Are you a Light Office Equipment and Supply Expert? Answer questions, earn points and help others
