Question about Westinghouse Televison & Video
My westinghouse tv and element tv both stopped working. they turn off after 1 minute or so
Posted by Rachele... on
Aron
  • Westinghouse Master
  • 2,090 Answers
Your TV might of had died on you guys and has stopped working too. Or it could be a power supply problems. It would be more cheaper to purchase another TV than to try and repair the current TV that is no longer working.
Posted on Dec 07, 2021
I have a white westinghouse 40 inch tv model vr4090 and the tv wont come on it shows the power indicator turn from red to blue but no picture or sound
Westinghouse tx-42f430s wont turn on fix repair - YouTube
? 5:29
https://www.youtube.com/watch?v=DdfLu5RdVEQ
May 12, 2014 - Uploaded by After Hours Tv & Pc repair
Westinghouse model # 32H1G1 won't turn on , but If I unplug the TV and wait for a ... -tx-42f430s-42-inch-lcd-tv-appears-bricked-595806.html ... I have a Westinghouse 40" TV that is working, but sometimes it won't turn on.
Westinghouse LED LCD TV Repair - YouTube
? 12:32
https://www.youtube.com/watch?v=DGg5iuFEfdM
Feb 8, 2014 - Uploaded by INSIDEHARDWARE CHRIS
Westinghouse Model: LD-4680 Similar (LD4655VX LD4255VX ...Samsung LCD TV Repair - TV Won't Turn On - How to Replace Power Supply ...
40 inch Westinghouse lcd tv black screen help - YouTube
? 1:39
https://www.youtube.com/watch?v=tKLRihGgZAs
Nov 21, 2011 - Uploaded by Jason Flynn
2answers
Westinghouse LD-4655VX Power on fine, nice picture, but around 5 minutes turn off self it
hi. the led tv turn off itseft aroun 5 minutes was complete shut off or another ?? need more data???
1helpful
Westinghouse - 60" Class /
Hello! I wanted to give you a few more codes that you may not have tried. I also wanted to give you the instructions to the power scan, which will scan the TV for the correct code. I hoep this helps!
Codes:
500
795
719
Power Scan:
1. Hold down the Clear TV button until all lights at the top of the remote light up
2. Press the red TV POWER button
3. Press and release the up arrow on the remote about once a second until the tv turns off.
4. When it turns off, press the # (Pound) button
5. Try powering the tv on/off, and try the volume. If one or more of these functions do not work, start over at step 1 again.
Becki Barned
DISH Network Customer Service
Display go's out in about 8 minutes. This is a Westinghouse LTV27W2
Tv turn on now.Dispaly go out about 8 mins,but does it still have audio?Yes,than the tv 1 or 2 long board call the LCD inverter boards are dead.These 1 or 2 long inverter boards help the tv to have backlight to produce a picture.Tries websites like Shopjimmy.com,Ebay.com to buy those 1 or 2 long refurbishes inverter boards for the replacement.
The tv turns itself off after 5 minutes being turned on
There can be several causes for this, few of which you can do anything about. However, a few things to try.
1) Replace the batteries on your remote control.
2) Try resetting the logic functions on your tv by unplugging it for a minute, then plugging it back in.
3) Try covering up the infra-red receptor on the front of your TV to see if you're getting unwanted signals from the receptor. taping a piece of foil over that area is perfect. If it doesn't stop after doing these two things you'll probably need to take it to a shop.
4) If this does stop it, then look for unexpected signal sources. Have you added a remote control extender? Added a new device to your audio-video system? Changed to a new remote?
Good luck with your problem...I hope you can work it out.
Westinghouse tv turns off by itself
There can be several causes for this, few of which you can do anything about. However, a few things to try:
I hope this helps. Joe
2helpful
My Westinghouse LTV-w1 will not turn off. None of
try unplugging tv to reset it,leave it off for a minute,and then plug in
HDMI Port not WORKING.
Try unplugging the TV for about a minute and then plugging back in.
3helpful
2answers
Model LTV-27w2 westinghouse
The tv got a heat sensor, the only way to fix tv , if you are a tv tech, is to buy a bottle of "freez it" spray small sections of tv in side. It will be clearly where the fault is if you spray correct part that give trouble. Replace that part and Tv will be Ok.
Televison & Video Logo
Top Westinghouse Televison & Video Experts
Paul Bade
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
