Question about HP LaserJet 4700 Printer
How do I fix a 59.53 error code - HP LaserJet 4700 Printer
I've run all component tests, swapped out ETB, fuser, and yellow cartridge. What do I do?
Posted by Shelley LaMarre on
Mehandi Husain Suleman
  • HP Master
  • 1,654 Answers
  • Display:
  • 59.53 ERROR
  • Description:
  • Yellow image drum motor startup error
  • Remedy:
  • Reconnect the connector J18 of the yellow drum motor and the connector J120 on the DC controller PCA. Perform the drum-motors component test in the DIAGNOSTICS menu. If the message persists, replace the yellow drum motor.
Posted on Dec 09, 2021
1helpful
I have a HP LJ 4700 printer set up to a network. It will print black but not colour
1. Go to menu set as default.
2. Do color calibration.
3. Print PQ test pages, observe the colors, chk
4. Print demo page. chk
5. Print from different file/system..
2helpful
I keep getting a "replace fuser kit" message on my
If you replaced with new fuser even getting same error, then check,
>Check the fuser connector (J5001). If
it is broken or damaged, replace it.
>. Check the connector (J1025) on the
DC controller PCB.
>. Replace the DC controller PCB.
In your best soulution for fixing the 59.30 error code on a hp 4700 printer it states to remove the duplex devise from the printer. what is the duplex device and where is it located
Duplex is here:
But 59.30 error (Fuser motor startup error/Black or N/A)
Follow next instructions:
Fuser motor error
1. Reconnect the connectors J4605 for the fuser motor and J1024 on the DC controller PCB.
2. Run the component test to verify that the fuser motor is working correctly.
3. Replace the fuser motor.
1helpful
How do I replace my HP Color LaserJet 4700 Image Transfer Kit? I don't have the manual for it.
Replace the ETB when a REPLACE TRANSFER KIT message displays on the control panel.
1. Turn the printer off.
2. Open the top and front cover.
3. Lower the ETB by pulling the green handle at the top of the unit downward.
4. Press the small blue latches located on either side of the bottom of the ETB and lift the unit out
of the printer.
5. Install the new ETB.
6. Close the front and top covers.
2answers
Ours's a hp color laserjet 4700dn ; the message is 59.30 error ; we bought the machine in the year 2007 what do you suggest?
59.30 states it's the:Fuser motor startup error
Based on the service manual here are the steps to follow:
Fuser motor error
controller PCB.
How to preform the component test below
1. Press Menu to enter the MENUS.
2. Press to highlight DIAGNOSTICS.
3. Press to select DIAGNOSTICS.
4. Press to highlight COMPONENT TEST.
5. Press to select COMPONENT TEST.
6. Select the component test Fuser motor. Use this test to rotate the fuser motor and drive gears.
Menus cannot be opened during component tests, so serves the same function as the Stop button.
More information on a Fuser motor failure detection
  • The DC controller determines the fuser motor failure and notifies the formatter of an error status when it encounters the following conditions.
  • Fuser motor start-up abnormality. The interval of the fuser motor speed detection signal does not reach the specified interval after 1.5 seconds of the fuser motor drive start.
  • Fuser motor rotation abnormality. The interval of the fuser motor speed detection signal stays at an irregular interval for two seconds and longer after it reaches the specified interval.
I've attached a screen shot of where the fuser motor is located It is # 8. tballone.png
1helpful
The copies are dirty, with black long tracks!
I would suggest either a fuser problem, If all Colors affected, or the Black Toner Cartridge. The Below chart may help isolate which component is malfunctioning. Repetitive image defects Measurement Component 24.7 mm (0.97 inch) Developer sleeve (Print Cartridge) 26.7 mm (1.05 inches) Charge roller (Print Cartridge) 32.9 mm (1.3 inches) RS roller 37.7 mm (1.48 inches) Transfer roller (ETB) 54.5 mm (2.15 inches) ETB rollers (ETB) 56.6 mm (2.22 inches) Fuser sleeve (Fusing Assembly) 62.8 mm (2.47 inches) Pressure roller (Fusing Assembly) 75.4 mm (2.97 inches) OPC (Print Cartridge)
2answers
2helpful
Define 54.18 ERROR code on a Hp Laserjet 5500
According to the HP Service manual, there is no 54.18 error.
The listed errors are:
54.1 Temperature error
Check the fuser. See 50.X fuser error.
54.3 Image density sensor error
Check the connections. Replace the color registration detection assembly.
54.5 Colour registration sensor error
54.6 Image density error
54.7(Y), 54.8(M), 54.9(C), or 54.10(K) Drum phase sensor error
Check the connections. Replace the drum phase sensor for the indicated color.
54.11(K), 54.12(C), 54.13(M), or 54.14(Y) Toner sensor error
Check the connections. Check the cartridge and replace it if necessary.
54.19 Transfer Belt error
Check the ETB connection. Replace the ETB. Replace the DC controller.
It is most likely that you have a faulty Toner Cartridge.
HP Laserjet Printer 4700 Fuser Error
Try unplugging the printer for 30 mins. You may still have a defective fuser.
26helpful
4answers
Hp color laserjet 4700dn error code 59.30
turn off the printer. remove the duplex device from the printer. turn on the printer. enter the diagnostic menu. enter the menu for sensor and motors. select the fuser motor and let it run. if you can hear it its ok (its not such a noicy one ... you have to listen very good) - follow up the next steps:
turn off the printer. turn on the printer. enter the service menu - pin code is: 09470005. set to 0 all counters for mono print, color print and the counter after service. leave the menu.
turn off the printer, reinstall the duplax device. turn on the printer.
result: the error msg is gone. its just HP wants to sell theyr service contracts.
HP LaserJet 4700 Printer Logo
Vinaya Kumar...
Vinaya Kumar...
Ekse
