Question about Seiki Televison & Video
The sleep time it is off. Is there probably a circuit that can interrupt it from proper operation?
What your describing sounds like an eeprom issue but it's impossible to know for sure without some voltage readings, do you have a multimeter and are you able to get the back off to get the readings? If not you could replace the main board but there is a chance it won't fix it
Posted on Dec 15, 2021
Question moved from Larry's Computer Forum to Seiki Television
Larry the Computer Guru writes.
And my own advice after seeing the issues that happen when Average Joe decides to fix his own television. It follows on from 'DIY Brain Surgery for Beginners', and seldom ends well.
IT IS NOT A COMPUTER AT ALL IT IS A TELEVISION
SO POST THERE. NOT COMPUTERS, THANKS.
https://www.fixya.com/troubleshoot/seiki...
Anonymous Dec 09, 2021
NOT TOLD AT ALL DOING WHAT , AS IN WHAT INPUT IS SELECTED.
DOES THE HDTV STATIONS GO DEAD TOO?????
USING THE ANTENNA, TUNER SET TO A GOOD STRONG STATION.
DOES A DVD DRIVE FAIL AS INPUT.
WE HAVE ZERO CLUES WHAT YOU ARE WATCHING
AND IF AN INPUT GOES DEAD THE TV WILL SLEEP (FOR THE eco REASON AND BURN LCD REASONS)
Anonymous Dec 14, 2021
yes , yes and yes.
yes it is bad
yes it needs service
and yes parts in it are bad.
what else needs knowing well ,you have no TV service skills, spare parts, or service manual nor tools, meters scopes and other key service tools. (large list deleted)
so what you can do is gue$$ or get it fixed.
NO INPUT Source told.
antenna, HDTV channel strong and clear
DVD player, deck hdmi
cable box, hdmi.
a home theater , AVR? connected HDMI
ROKU (or the like) HDMI connected, well mine goes to standby mode unused.
and and endless list of other things HMDI, not told
we can not see your TV nor its connections ever, unless told or photos of it all
https://www.fixya.com/support/r29790007-repairing_own_television
Posted on Dec 14, 2021
Sleep mode on a Windows 7 PC saves power without you having to turn your computer off and without losing any work.
This option cuts the power to your monitor, powers down the hard drive and pauses all functions until you awaken the computer from hibernation.
Whether you have a laptop, desktop or workstation, putting your computer into sleep mode will lower your electric bill and save money!
Click the "Start" button in the lower left corner of your desktop. In the lower right corner of the Start menu, next to the "Shut Down" button, is a button labeled with a small, right-pointing arrow. Mouse over the arrow.
The Shut Down menu appears.
Point at "Sleep" and click on this option.
Your Windows 7 computer goes into sleep mode.
Wake your computer from sleep mode by jiggling the mouse.
There may be a delay of a few seconds before your hardware powers on.
All of your open programs are still open and your work is intact, just as you left it before the computer entered sleep mode.
Configure your Windows 7 PC to go into sleep mode automatically when it is not used for a certain amount of time.
Click "Start" and select "Control Panel." Click "System and Security."
Click "Power Options."
A menu opens.
Click on "Choose when the computer sleeps" and select the number of minutes of inactivity. You can also set a separate time interval to put your monitor into sleep mode.
If you set both to 10 minutes, then your PC and monitor will automatically go into sleep mode after 10 minutes of inactivity
Your Computer in sleep mode
First, save all of your work. Information in computer memory is not saved while your computer is on standby.
From the Start menu, select Settings, then Control Panel, then Power Management.
Click Standby Beside When I Push the Power Button.
Push the Power button.
Automatically Putting Your Computer on Standby
Save all work before leaving your computer.
From the Start menu, select Settings, then Control Panel.
Double-click Power Management.
Set the times that you want your system to go on standby, to shut off the monitor and to shut off the hard disks.
Click OK. Your computer will go on standby according to the schedule you have entered.
Putting Your Computer in Hibernation
Double-click Power Settings.
Click on the Advanced tab.
At the When I Push the Power Button On My Computer screen, click Hibernate.
Click the Power button.
Hope this helps.
Dani what is a Seiki computer, we can not guess PCs not at all , all I can do is beg , you.
yes , yes and yes.
yes it is bad
cable box, hdmi.
we can not see your TV nor its connections ever, unless told or photos of it all.
