Question about RCA Televison & Video
I have a 65 inch rca tv that won't turn on I have power red light for off and blue light for on tried factory reset no luck any ideas on what part needs to be replaced
Posted by Steve Sha on
  • Meganonahue
    Meganonahue Dec 06, 2021
    [ JOIN US ] I get paid more than $60 to $70 per hour for working online. I heard about this job 3 months ago and after joining this I have earned easily $10k from this without having online working skills . Simply give it a shot on the accompanying site…
    Here is I started.……......>> http://Www.NETCASH1.Com
Larry
  • RCA Master
  • 3,895 Answers
This model tv had issues with backlight failure, I'd start there
Posted on Dec 07, 2021
Testimonial: "I put flash light up too screen to see if I could see picture and could not I think if it was back light I should be able to see something on screen is this correct?"
  • Larry Dec 07, 2021
    Sometimes it's hard to see an image with a flashlight, it could be either the main or power board and both boards can be tested with a multi meter for backlight issues, if your getting the command from the main to the power supply to enable backlights then the main is working, you can test the backlight b+ to frame ground to see if that supply is working and the rest of the voltages are normal, readings are stamped on the board. Sets I work on with no backlights there have been several times I couldn't see an image on the screen and it was backlights, 90 out of 100 are bad backlights other 10% are board or other issues
  • Steve Sha
    Steve Sha Dec 07, 2021
    Thank you for the information
Arnie Burke
  • 7,084 Answers
If u used set alot it cud b worn. They make electronix cheap taday. Cud b xpensive for repair n then anothr issue comes up. Buying new may b bettr. Iwud check utube n pinterest for repair videos
50 inch rca tv model number RLDED5078A-E Red LIGHT COME ON BUT NO BLUE LIGHT AND No REMOTE For TV
OMG THIS is what we in the TV repair business call the walmart syndrome, we see this all the time with those RCA usually a walmart rebrand.
it is hard to guess what is really wrong but i would start with the power supply (yellow board and test it voltage outputs with a multi meter. each pin off the power board has specific voltages that can easily be measured. In this case though it could be other than the power board since you have red light indicating that at least the power board has 5 volt standby power. If you have no idea what I am talking about take it to a shop
Westinghouse ew32s5kw tv red light shows power is going to unit pressing power turns indicator light from red to blue for a brief moment then back to red.
I had the same problem on my Westinghouse 32 inch TV. The internal main power supply went bad and had to be replaced. I had a TV repair shop do it. It was about 8 years ago. Haven't had a problem since. I think it cost about $70 for parts and labor. Nowadays TVs are pretty much a throw away item if they go bad. TV repair shops are getting hard to find plus the cost of TVs has come down so much sometimes you can get a new set for what the repair would cost!
2answers
Westinghouse 55 inch tv red light stays on blue light comes on and turns back off I have replaced the power supply board already because it was on when it all went off no power at all
Hi i would need more info. what is the model number. its not always the power board it can be a processor fault. and thats the main av board. the processor is what turns on all the parts to start up.
When i turn on my tv it tries to boot, blue mitsubishi home screen come up, i hear fan then it all shuts off while green light blinks.
Try a reset. Start by unplugging for 1 minute, then plug back in & if still won't restart try the following. If none of the following work, you will need a technician.
Initializing the TV in many cases can remedy a problem.
In the 2006 product line Initialization is now a user function.
Pressing the front panel "INPUT' and "FORMAT"
buttons at the same time activates Initialization. When
complete all user settings will have to be set again. The
table in Figure 4-3 list the User Initialization procedures.
Note: Pressing INPUT and FORMAT is the same as
the Initialization in the Option Menu (MENU-2-4-7-0)
Order Name Procedure Results Notes
1 System Reset Press <System Reset>
on Front Panel
Hardware & TV operating
software reset.
POWER/Timer LED flashes for 60
seconds. No customer settings
are changed.
2 User Initialization
Press <INPUT> &
<FORMAT> on Front
Panel at the same time.
All customer Audio &
Video settings are reset to
factory default.
All customer settings will need to
re-configured.
3 Reset System
Defaults
From the remote, press
<MENU> <1-2-3>
<ENTER>
except V-Chip are reset to
factory default.
Netcommand, Channel Memory,
etc., will need to be re-configured.
SERVICER
PROCEDURE 4 Initialization
<MENU> <2-4-7-0>*
select "INITIAL" press
<ENTER>
All customer settings are
reset to factory default.
re-configured.
MITSUBISHI RESET / INITIALIZATION CHART
CUSTOMER
PROCEDURES
Figure 4-3
Figure 4-4
LED Indications
The front panel LEDs, refer to Figure 4-4, also assist in
determining the cause of a symptom. Figure 4-5 illustrates
normal LED operation. Figure 4-6 shows the
LEDs response when a problem is detected and indicates
the possible cause.
Power/Timer
Indicator
Status
Indicator
Lamp
Indicator Condition
Off Off Off Off (standby)
Blinking green
fast Off Off Initialization (10 - 65 seconds)
Off Off Blinking
green fast Lamp runs for 1 min after PTV off
Green Off Off Power On
Blinking green Off Off Power On Timer is set
NORMAL LED INDICATIONS
Power LED Status LED Lamp LED Condition
High Temperature - check ventilation air flow.
(Temperature sensor is disconnected.)
Off Off Blinking yellow Lamp cover is open.
Lamp failure (Lamp fails to turn on)
Off Off Red (Lamp turns off after lighting)
Lamp is broken
Off Blinking Red Off Fan Stop
Off Red. Off Circuit failure. (Run Error Code Check)
2answers
RCA LCD TV red light flasiing tv won't come on
Bad main logic board. Probably won't be able to find it. You can try Encompas Parts. Good Luck to you.
This TV has a light bar on the front that is red when off and blue when on. When we attempt to power the TV on the light will momentarily light blue, then turn red and the TV won't power up. It...
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
Any ideas on what to do for an element tv that won't turn back on..the red/blue light is not on either. It was working fine and when I shut it off the red/blue light went out also now I can't get it back...
Tries tv unplug,replug it back like about an hour.By letting the tv resetting itself back to the tv factory setting.Now,the tv should be working again.If it still have the same result.Mean the tv power supply board,that the board where the power a/c plug into it.The causes and the problems.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
RCA TruFlat HD27F534T - No Power
Does the red light come on on the front of the TV to let you know it is getting power? Does the menu come on? If the menu desn't come or the red light you might need to take it to RCA or a good repair place. If you checked different outlets it sseems to be a TV problem.
RCA Red P
Try hard reset==leave unplugged from AC overnight.
Televison & Video Logo
Top RCA Televison & Video Experts
 Francisco Mauricio...
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
