Question about GE Washing Machines
GE top load washing machine stops spinning. Model wjrr4170eww
I have a GE top load washing machine, model number wjrr4170eww. Machine no longer spins, so the clothes are soaked. Can you please help
Posted by Mark Richard on
ruggeg
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 81 Answers
The door switch is defective. It stops the machine from spinning when the lid is opened. Go to repairclinic.com for help and parts
Posted on Dec 30, 2021
2answers
Spin. Working short time do not put cloth water out
Sounds like the belt that spins the washing drum is slipping. It my need to be adjusted or replaced, or try washing a smaller load of laundry.
Model WPRE6100GOWT; Serial #AM931842G does not spin the water out.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
I have a GE top load washer Model WJRR417G1WW did not spin out after rinse cycle.. any idea? Jen
heatman101
GE model wwse5240G washer suddenly stopped working full of water
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
If you are having problems with your front load washing machine then checkout this tip...
heatman101
Water does not drain from te washing machine. Can I do anything to addrfess the problem. I don't have the exact model. It is a GE top load.
heatman101
My GE Washer Model # S2100 will not spin dry every thing els works
heatman101
I have an amana Model ALW880QAW Top Loading Washing Machine. It sounds like a bearing is going bad when the washer is in the spin cycle. I am familiar with repairing applicances and I would like to know if...
I have an Amana top loading washing machine.. The machine recently emitted a burning odor and the machine has stopped spinning. when turned to spin cycle there are bumping sounds and it no longer spins. Does this model have a belt which might need replacing or does it have a transmission and does it sound like possibly extensive transmission work. If it is the transmission, is it likely repair costs would be greater than the value of this machine?
GE top load Profile washer. Spin cycle not
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Open Questions:
Washing Machines Logo
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Gerry Harvey
Gerry Harvey
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
