MGHA-056ABFC-02 repair manual - Heating & Cooling
Posted by ray6446 on
Model #Mgha-056abfc-05. Why doesn't blower operate?
if when first comes on see if voltage to fan motor if yes bad motor if no voltage bad control board
Intertherm wiring diagram for model number MGHA-056ABFC-05
you have a 24 volt shorts check your thermostat wires to see if they are frayed or if they are touching anything. Check your outside wires also go to the thermostat.
I need a wiring diagram for the mgha-056abfc-01
If my pilot stays lite, why wouldn’t be my furnace be forcing air? Could it be a switch or maybe somebody wired it different? Should I just buy a new furnace so I don’t have to go behind someone’s wiring? Question I need answered thanks!
Mgha-056abfc-02 Owners Manual
Hell no! This is so blown out of portion.
SAY NO TO THE MASK!
WHERE DO i GET A BURNER PILOT FOR A NORDYNE HEATHER SERIAL # MGH9412-04786 MODEL # MGHA-056ABFC-02
Nordyme makes a lot of different units. Go to Nordyne.com service and parts they can help. Rus
Open Questions:
0answers
Why won't my Reddy Heater R55 run with the upper shell on? My Reddy Heater R55 will not run properly with the upper shell installed. Initially, the unit wasn't sparking, so I replaced the transformer ignition control and installed a new spark plug. That fixed the sparking issue. However, this new shutoff issue was discovered. I elected to replace the lint filter, intake filter, and output filter, as those pieces all looked pretty old. The filter end cover was cracked on the side and spitting out air, which I replaced. After the same issue continued and the unit shut off after a few minutes with the upper shell on, I replaced several other things. This included the photocell, nozzle and adapter, the adjusting screw, spring, steel ball, and the 1/8" ID air and fuel lines. After digging deeper into this, I noted the old 3/16" ID air line was leaking with a bit of soapy water, my dad's best trick for finding leaks. One thing to note, when I have the upper shell off, I have set the pressure to 3.4 PSI (per the side label), but when I put the upper shell on, the PSI drops to below 3.0 unless I hold the gauge still. When I hold it, the gauge reads 3.4 PSI. A couple of final things to note on this journey. 1) The fuel cap does not look to have a gasket but it seems to breathe properly with the hole in the center of the cap. 2) Before any issues started, I was running pump kerosene. Since then, I filled up with 10 gallons of jet fuel at a local airport and wondered if I got bad fuel from them. I plan to run through the last 7 gallons or so of jet fuel with the upper shell off and then try a couple of gallons of pump kerosene to see if that resolves the problem. Beyond all of my attempts, I am at a loss and could use some help. I've spent more on these repairs than the unit is worth but started the process in hopes of fixing the heater, as my wife's grandfather gave it to me a couple of years ago. In hindsight, I should have just bought a new unit, but here I am.
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
john h
