Question about Panasonic NN-CD989S New
Had a H97 fault code on panasonic nn-cd989s. Microwave did not run. Replaced one door switch. Now the microwave runs but only for 3 seconds. Is there another issue?
Posted by John on
1helpful
Panasonic convection oven nn-cd989s, complete power off during prebake cycle of 450 deg which was directed to remove light oil coating from manufacturing process . Now unit has no power on face panel
Check the 20 amp fuse where the power cord ends inside the oven. If it is open check the latch switches. If the switches check ok the invertor is probably bad, smoking.
Stove top light on Microwave will not shut off.
There's a relay in the microwave that is not working.
Why my microwave NN GD371M will run for 4 seconds then shut off. display shows code h97?
There are a number of possible causes.
The following link will take you to a page with the diagnostic flow chart that you can use to troubleshoot this issue:
Microwave Fault Codes
This customers review of that issue may also be of some help:
Customer Reviews Panasonic NN T945SF 2 2 Cubic Foot 1250 Watt Microwave...
14helpful
My Panasonic NN-ST657W microwave has suddenly come up with an H97 code on display panel. Switches off after about 6 seconds before displaying this code. What has happened?
This oven is programmed with a self diagnostics failure code system which will help for troubleshooting, H97, H98 and H99 are the provided failure magnetron and inverter circuit problem areas. This section explains failure codes of H97, H98 and H99. H97, H98 and H99 appears in display window a short time after start key is pressed and there is no microwave oscillation.
There is not a lot the layman can do except maybe to try a new magnetron.
It is a job for an experienced Panasonic Microwave repair man.
We have a Panasonic Microwave model number NN-t945SFX. We were using our microwave as a Inveter Turbo Defroster as we prepared our meal. Seconds after, a family member decided they wanted popcorn since...
NN-T945SFX May 27, 2017
H95, H97, H98 or H99 mean that there's a problem with your inverter, magnetron, or digital programming circuit.
If it stops after 7 seconds, it likely has a problem with the inverter.
It may be a loose connection in the wiring between the inverter, magnetron, and/or control board, or maybe one of those components has failed.
Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here.
FixYa doesn't notify me when there's a response, so if you have other questions, please contact me directly.
- William E. Miller, AS-EET
[email protected]
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
17helpful
Error code h97, on a genius prestige microwave - nn-sd787st. what does this mean?
Hello :
Troubleshooting of Inverter Circuit (U) and Magnetron .
WARNING :
The microwave is capable of giving you a serious electrical shock even when it's unplugged , so I recommend you to call a repair technician for help .
please don't forget to rate .
good luck .
Panasonic NN-CD989S New Logo
Top Panasonic Microwave Ovens Experts
Paul Bade
Oloyede Monsuru
Ekse
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
