After power outage DSR-25 won't go into stand-by (red light on power button). Key INH is off. Thanks, Tom
Never mind. It just went into stand-by by itself.
  • MariaGilbreath
    MariaGilbreath Dec 23, 2021
    [ JOIN US ] I get paid more than $60 to $70 per hour for working online. I heard about this job 3 months ago and after joining this I have earned easily $10k from this without having online working skills . Simply give it a shot on the accompanying site…
    Here is I started.……......>> http://Www.NETCASH1.Com
Larry
  • Televison & ... Master
  • 3,876 Answers
Sounds good.
Posted on Dec 22, 2021
How do I fix my panasonic vierra that won't come on after a power outage?
Pull the plug and with the power disconnected hold the power button on for 60 seconds. After at least the 60 seconds plug the tv in and try to start it. If it works great if not , hold the power button in the on position for a count of 20 with the tv plugged in . If theres still no Joy try power with one of your volume buttons at the same time . One of these should provide a hard reset for the tv.
SOLVED 50 panasonic Viera model no TC P50C2 won turn on red light blinks...
JVC LT-22EM72 Solid red power indicator but tv won't turn on
Customer service told me to leave the unit unplugged for 24 hours.
2helpful
2answers
Flashing green light on control panel
Samsung refrigerator RS2530bwp
Cause: Power outage
Symptoms:
- One LED light flashing on console (in the Power Freeze section)
- Not running (not cooling, but inside lights work, ice maker not working, ice crusher doesn't work, water wont dispense)
Solution:
Press and hold for at least 10 seconds
Ice type button + Filter Reset button
Console should light up.
This is not documented *anywhere* on the web (until now). Best of luck
LG 37LG30 model won't come on after power outage. Red light is on but we can't get the TV to turn on.
Good day!!!
Red light it means that you have power on the TV but the system is stand by due to faulty parts...
Normally if your TV is on standby mode every time you attempt to power it ON...That problem are 2 causes its either power supply board or main board..
So lets find out...Just follow this procedure to determine what are the faulty parts..
1. Open the back cover.
2. Check the power supply output...It should have 5vdc for the main board..12vdc or 16vdc for the audio and 24vdc for the back-light inverter..
3. If those 3 voltage supplies have encountered voltage drop...The problem could be on power supply board..
4. If the power supply output is normal..The problem could be on the main board...
5. If the problem is power supply you should check if the capacitors are bulged on the top and try to replaced it..If you can't do that you can purchased new power supply board..
6. If the problem is on main board there is no D.I.Y repair on that so you need to buy a new main board that fits to your TV..
If you have any clarification or query..Just add a comment..
Hope this solution will be helpful..
Thanks for using fixya...
7helpful
2answers
5helpful
3answers
Sony DSR 25, error code C3140. Any advise. Only comes up when tape is inserted.
FG fault when starting drum.
It’s very possible that you have a bad drum motor.
3helpful
Sony dsr-25 switches on, goes into stand-by, then won't start up
There is a "Key INH" button on the front. You want to turn it to "off".
Sony DSR 1800 red light under condition
dear this problem is related to the tpe path of the vtr .
you can have your vtr checkd at nearby service centre
Jamed tape
This happens often in my business. Sony DSR is the most delicate cassette compartment out there. It also sounds like the unit is in auto off mode(electronic proublems as well). Please for your sake take this unit to Sony or some one qualified to repair this. You should expect replacement of the compartment and what ever damage occured while removing the tape. Parts for these decks are not cheap, If you had taken it to a service person with the tape stuck inside the monitary damage would far less. The one good thing is this is a consumer unit, if it where a DSR 1500 two models up it would pro and they share parts price for repair x3 across the board.
Televison & Video Logo
Top Televison & Video Experts
Ekse
