Question about Comfort Glow Heating & Cooling
Comfort glow gas wall heaters pilot light wont light
Seems like the gas coming out of the pilot light is blowing the match out when ivtry to light it
Posted by Scotty Greenwood on
David Spradling
    Top Expert:
  • Comfort Glow Master
  • 12,237 Answers
Clean or replace pilot gen weak flame
Posted on Jan 16, 2022
Can't light pilot due to breeze coming out of unplugged gas wall heater
It sounds like you have a direct vent heater so you have to take off a pilot access cover to light the pilot. So what happens is the draft coming out of the cover is blowing out the match before you get it in the hole. The trick is to get the match or lighter in the hole quickly as possible so the pressure inside the heater will equalize and the match will stay lit. Then you should be able to lite it. Get it inside the hole fast and it will work. Don't forget to put the cover back over the pilot access or the draft may cause the pilot to go back out.
2helpful
Pilot won't light
You may have to bleed some more air out of the system.
Your ODS pilot may be clogged with dust or lint and needs to be blown out with air(less than 30 psi).
Your regulator or gas valve may be faulty.
1helpful
Have Model CGP30TB Copmfort Glow propane heater. Pilot light won't stay lit. Flames also coming from what seem to be air vents just below flame on pilot light.
sounds like an obstruction in pilot assembly.try using canned compressed air to blow directly into pilot. this technique is successful about 70%. if not,pilot assembly must be removed and cleaned thorougly
Patio comfort heater won't light
Sometimes you have to completely disassemble the pilot assembly to clear the blockage, the orifice for the pilot jet is very small and you can not get directly to it unless you take it apart. If this does not help, you may need a new valve.
20helpful
4answers
Comfort glo propane ventless heater won't light
I have several of these heaters in my rent houses and love them. The most problem I have is not being able to ignite the pilot with the user control igniter. Remove the screws that hold the front cover in place along with the front cover. Hold the pilot control down and ignite with a lighter. Keep the pilot engaged until thermocouple is warm enough to keep pilot gas flowing. If it will light this way then you need to blow out the pilot orifice. It seems that every year I have to go in after the summer season when the heater is off and clean the pilot/orifice lines with high pressure air. I believe spiders/bugs/dust block pilot orifice when it is not in use. You can also tell that orifice is blocked when you don't get a good blue pilot flame with pressure behind it allowing the flame to submerse the thermocouple. If the the thermocouple is not getting enought heat it will turn pilot gas off for safety reasons.
Heater wont work on high setting
Clean the burner with a wire brush and vacuum the ceramic. Blow out the heater, remove dust, cobwebs, and lint from it.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
2answers
Comfort Glow Vent-free Gas Heater CGN18B
the pilot light is operated off a millivolt generator. that is the small tube directly in the pilot flame. its purpose is to generate a small dc current which is connected to the pilot valve inside the main valve. setting the control to pilot opens just the pilot gas supply. when operating normally the millivolt generator keeps a small electromagnet pulled in that keeps the pilot gas supply open. if it don't work the pilot gas supply valve closes. replace the thermocouple.
Heating & Cooling Logo
Top Comfort Glow Heating & Cooling Experts
Vernon Taylor
ray gallant
Are you a Comfort Glow Heating and Cooling Expert? Answer questions, earn points and help others
