Question about Samsung Televison & Video
Samsung refrigerator model number RFG298AAWP. No power all of a sudden and the light on front keeps blinking click click
Now the ice maker keeps running but we have still have no power. The inside led top lights very lightly flickers on and off here and there. We never have used the ice or water since we got it.
Posted by Jennifer on
  • MariaGilbreath
    MariaGilbreath Dec 23, 2021
    [ JOIN US ] I get paid more than $60 to $70 per hour for working online. I heard about this job 3 months ago and after joining this I have earned easily $10k from this without having online working skills . Simply give it a shot on the accompanying site…
    Here is I started.……......>> http://Www.NETCASH1.Com
Larry
  • Samsung Master
  • 3,898 Answers
Could be a control board issue
Posted on Dec 22, 2021
1helpful
Samsung RFG298AAWP refrigerator gets warm. I unplug, plug back in, gets cold. Then few days later, same cycle.
Check for icing of the evaporator (cooling) coil located behind the cover on the back wall inside. There is a cooling coil with a fan to supply the cold air for the refrigerator. Otherwise you might have a control board issue. The iced coil is much more likely. There are repair kits for ice build up and/or defrost problems. To get the proper parts for Samsung you must supply all the ID numbers including full model, full serial number and BOM number (if it has one.)
How to reset a samsung refrigerator model number rs261mdpn aftthea power outage
http://www.searspartsdirect.com/partsdirect/part-number/Samsung-Parts/Refrigerator-Parts/DA41-00669A/0046/401/Model-RS261MDPNXAA/1482/0165000
this is the control board you will need for your model if unplugging the unit for 5 minutes doesn't fix the problem. If they are LED lights, then I point my finger at this. This is a plug and play board with molex connectors. Very easy to install with unit unplugged. You can manually reset the display and check for error codes by holding the top left and top right button on your user interface for 5 seconds in unison FOR 5 or more seconds after all the lights flash.
2answers
What do the flashing blue lights mean on front of refrigerator?
Flashing blue lights on front of what model Samsung refrigerator?
The power keeps shouting down and red power light flashing
With not knowing the model number I will give a general answer but keep in mind most Sony (it is posted here as a Sony) have a blink code where front power light blinks a specific error code----3 or 5 or some number of blinks and pause and repeats---that with the model number might narrow it down.
Sharp Aquos LC-52E810UN does not turn on, front bezel indication light only blinks
Transformers fail on your power supply board. Go to the Sharp website put the model number in and serial number and in order and you can order a replacement parts. You can find out how to replace it via YouTube it's not as hard as you think
5helpful
2answers
Dash light on monitor no refrigerator temperatures shown on monitor how to reset
Hi there, I have the same problem with my samsung side by side the model no is- RSA 1Wtmh .
The light started blinking after a power cut and the elec came back on and the fridge light just blinks on panel instead of showing temp (the fridge and freezer are working)?
11helpful
3answers
Samsung model RS2556SH, refrigerator
I have a Samsung fridge model no. RS2556sh. We lost power and when the power came back on the fridge did not. The LED is blinking in the top right corner and the lights or on inside the fridge but not cooling in either side. It doesn't sound like the compresser or any of the fans are coming on. So, what's wrong?
2answers
Our samsung RS267BARB fridge's light is blinking and feels warm
If you cannot reach the plug, then turn off the breaker that feeds it in your electrical panel; most electrical codes require a separate power feed for refrigerators.
2answers
My samsung tv wont turn on, red light keeps flashing on the front.
i had this with my samsung and my mums instead of pressing red power button press either switch from analog tv to digital button or just press a number
Open Questions:
Televison & Video Logo
Ekse
 Francisco Mauricio...
