Question about Action Cameras
My pyle sports pschd30 will not power up I connected it to my computer the charging light does not come on
Posted by Thomas Osuski on
Pyle pcau44 amp
A fuse is blown, check main supply fuse.
My Pyle amp cut off and will not turn on
  • Ensure the device's power switch is on
  • Make sure the device has power connected.
  • Contact Pyle -->
    1-888-318-PYLE / 718-535-1800
I've purchased a Pyle amplifier... It doesn't work!
your first mistake is buying anything pyle..... check your remote wire that should do the trick
I have Pyle PLTDN71, everything is wired properly , but it only plays music for 3 secs and cuts off. The problem is repeated everytime the unit or car is restarted... anyone ???
u probably connected ur power or constant to ur lights. if ur lights turn on ur accesry switch and than ur ight if ur stereo turns off thanu have tosee witch wire is connected wrong
2helpful
Trouble connecting marine amp to stereo
Hello lizskates814,
You can use either the high level (speaker) or the low-level (RCA's) inputs to the amp, but not both. Choose whichever one sounds the best or is more convenient to install and leave the other disconnected.
Hope this helps.
Cameras Logo
Top Action Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
ADMIN Canada
ADMIN Canada
Tom Chichester
Are you an Action Camera Expert? Answer questions, earn points and help others
