I've had my Haeir HLPW028BXW portable washer for 3 years now. I can't complete the wash because the the spin cycle doesn't work. The water drains out but everything is soaked because it wont spin.. I get a UL code when I get to the spin cycle and it beeps. I did all the troubleshooting leveling the clothes out, restarting, unplugging, draining hose and still the same code. I also checked the belt and it's in great shape and not loose at all. Any other suggestions?
If resetting the washer doesn’t work, the limit switch may be stuck. The sensor for a unbalanced load is a limit switch. The switch should snap back into standby position when the wash tub comes to a stop. Sometimes the switch will stay stuck. Move the barrel by hand back and forth until it hits the inner walls of washer. It may knock the switch back in place.
Testimonial: "Ok. I tried moving the barrel around but nothing happened. Is there a way I can click the switch with my hand. Where exactly is it located? ...Thanks"
