Bluetooth wont become an output speaker after pairing
Jonatan Hermansson
  • 20 Answers
If you have a Bluetooth dongle lying around to test, you should try it. This will narrow down the problem.
Posted on Dec 09, 2021
How do I pair my beat 200 BT car stereo
If you're referring to the 200bt portable speaker set, this isnt possible. Car stereos are only designed for input over bluetooth not output. Now if it really important to you, you can use a line level adapter to tap into the rear speakers of your vehicle, take that output and plug it into your speakers with an aux cord, or if you have an after market radio you can use RCA cables and a jack adapter to do the same. If you must bluetooth (eg. out of vehicle operation of speakers) buy a cheap bluetooth output adapter (shark makes one) use a small cigarette lighter inverter to power it, and then you can plug your aux jack into it and bluetooth to a speaker set outside of the car. If you use this in conjunction with the speakers car there will be a delay between those speakers and your bluetooth speakers.
My model#pbt3027blk wierlesspotable bluetooth speaker pairs whith my phone when i play music from my phone the portable polaroid speaker puts out no sound how to fix
When you pair the speaker to the phone the Operating system on the phone becomes aware of the Bluetooth device. An APP is needed to transmit the music over the bluetooth to the speaker. The documentation that came with the speakers should have information of where to get the APP.
1helpful
How do I pair my I Pad with my new Philips portable speaker using bluetooth ( can connect fine using a cable)
If your portable speaker is Bluetooth-enabled, here is the general procedure:
1. Press and hold the function control button on the speaker until you see red and blue lights flashing in rapid succession on the speaker (the speaker is now in "pairing" mode).
2. Turn on Bluetooth on your iPad and then tap on Scan. iPad will begin scanning for nearby Bluetooth devices. When you see a name similar to that of your speaker, tap on it . You will be asked for a passcode/passkey to pair the iPad with the speaker. Enter '0000' or '1234' (without the quotes).
3. Once the passkey is accepted, the two devices are now paired. The light on the speaker should become a steady blue.
4. On the iPad, tap on Connect. If the iPad connects to the speaker, you will see Connected. You are done. Play some music from the iPad to see if you can hear it coming through the speaker.
You should have this procedure detailed in the set up guide that came with the speaker. Please note that pairing is required only for the first time you try to connect the two devices, to get them "acquainted" to each other. After that, all you need is to connect the iPad to the speaker every time you want to listen to your iPad through the speaker.
3answers
How do I pair speaker with phone
turn both phone bluetooth and speaker bluetooth off. then turn them back on. the speaker's light should be flashing indicating its searching for a device to pair with. as its flashing make sure your phones bluetooth is visible and searching. they will pair and your phone will tell you and the speakers light should quit flashiing and just remain on.
2answers
How to get bluetooth speaker to connect already apired and is showing but wont connect
Hello, I have already met this issue: after pairing a bluetooth speaker on a first host (computer or iPad), then pairing it on a second device (as another computer for example), when I try to pair it again to its original host device, it doesn't work.
The solution consist in
1) on the host computer, in the list of the Bluetooth devices, delete the line of the bluetooth speaker and forget this bluetooth device,
2) push on the Bluetooth detect button on Bluetooth speaker,
3) scan the bluetooth devices on your computer host, and when you see the bluetooth speaker in the list, select it.
2answers
My iPhone don't work with my Bluetooth speaker system
Paired is not connected. Connecting is the next step after pairing. Then make sure that the ilive speaker is set as the dudio output device.
2answers
Blue tooth speaker wont turn back on.
Unable to connect to a device?
Before attempting any of the following steps, make sure that you are running the latest software version on your SoundLink Wireless Mobile speaker. Click here to visit the software update center and update your speaker. If you are still having difficulty connecting to a device after updating the software, continue to the troubleshooting steps.
Unable to connect with a previously paired device?
Please try the following to resolve this issue:
Perform a product resetTo perform a SoundLink speaker reset, following these steps:
  1. On the speaker, press and hold Mute for 10 seconds, the LEDs will flash briefly
  2. Press Power to turn the SoundLink speaker back on
Clear the pairing list on both the SoundLink Wireless Mobile speaker and the source
  1. On the SoundLink speaker, press and hold the Bluetooth button for approximately 10 seconds until you hear a tone. The SoundLink speaker clears all Bluetooth devices from its memory and becomes discoverable
  2. Clear the list on your Bluetooth device. For more information, please refer to the manufacturer of the device
  3. Perform a product reset. On the speaker, press and hold Mute for 10 seconds, the LEDs will flash briefly. Press Power to turn the SoundLink speaker back on
  4. Try pairing the device again by following these steps:
    1. With the Bluetooth device and the SoundLink speaker both turned on, press and hold the Bluetooth button on the speaker for three seconds to make the speaker discoverable. The Bluetooth indicator will slowly fade on and off approximately once every second to show the speaker is in discoverable mode
    2. Set your Bluetooth device to "Discoverable." This will allow your device to discover the SoundLink speaker
    3. On your device, locate the Bluetooth device list. Select "Bose SoundLink" from the list
    4. If your device asks for a passkey, enter digits 0000 and press OK. Some devices also ask you to accept the connection. Your Bluetooth device indicates when pairing is complete. The SoundLink speaker indicates pairing is complete when the Bluetooth indicator stops fading on and off and remains on
Be sure the SoundLink speaker is within 30 feet of the Bluetooth deviceThe system is designed to operate at a range of 30 feet. However, performance can be diminished by obstacles such as walls or metal, and may also be affected by other Bluetooth devices. Try moving the SoundLink speaker closer to the Bluetooth device.
Be sure the source's Bluetooth function is OnMany Bluetooth enabled devices have an option where the Bluetooth feature can be turned On or Off. This option may be set to Off to save the battery life of the device. Be sure this option is set to On. If the Bose product is paired to the Bluetooth enabled device, it should automatically reconnect when its Bluetooth function is turned on. If the Bose product doesn't automatically reconnect, manually select the Bose product within the Bluetooth list on the device.
Manually connect the SoundLink speaker in the device listSome devices will pair to a device but not automatically connect. Go to the pairing list of the device and check if this is the case. If it is, try connecting to the SoundLink speaker.
Why I can't bluetooth pair with veho VSS-006-360
Hope it helps.
Power off your N8.
Remove battery from your N8 and reinsert again and then power it back on.
Activate Bluetooth settings and program it to become discoverable
Power off your bluetooth speaker
Remove battery from your Bluetooth speaker and reinsert.
Power it on again
Allow the pairing to proceed for both devices. Check and confirm/test whether operational
1helpful
When I have my headphones in the volume works but when I take them out it dosn't work anymore
THIS MAY HELP!
For PSP Go owners, a very cool feature is the ability to pair bluetooth devices with the system. This recipe will show you how to toggle between outputting audio between the PSP Go’s speakers/headphone jack and a bluetooth headset/speaker.
1. Pair your bluetooth device with your PSP Go.
-Go to Settings > Bluetooth Device Settings
-Be sure to turn the Bluetooth Connection ON. Then select Manage Bluetooth Devices.
-Click on Register New Devices; put your headset into pairing mode and pair it with the PSP Go by following the onscreen prompts.
2. Once your headset/device is paired. Be sure to leave the Bluetooth Connection on.
3. Finally, open up the music player or a game and when you want to switch between the PSP Go’s speaker or your headset, just hold the Audio button on top for about 7 seconds. It will change the volume icon w/a bluetooth icon and audio on your PSP Go should start outputting via your headset.
To toggle back to speakers/headphones, again hold the audio button for about 7 seconds and it will switch back.
This should work with any bluetooth headset and does not require it being a stereo headset (ie any $5 headset should work).
Ekse
 Grubhead
Grubhead
