Question about Horizontal Computers & Internet
How to remove Horizontal Lines On Laptop Screen ?
Please suggest me something about that....
Posted by mia henry on
  • 1 more comment
  • Anonymous Dec 04, 2021
    I can not see your screens failing, a huge problem asking the blind ,now?
    NO PC brand told
    no PC model told the 2007 models delivered to USA had bad GPU chip, (BGA solderball ROHS failures)
    why post at all lacking what PC you own of 100,000 models or more, world wide.
    if you bend the screen bezel and the lines change? the LCD is bad. (or cable inside loose)
    does it do the same on the BIOS screens,?
    causes:
    bad LCD screen
    bad cable to screen
    bad GPU chip
    bad GPU chip driver.
    one more, the PC power rails can be overloaded with some old now bad main battery causing DC power to be weak
    and the GPU (screen) chip goes wonkey. (malf's) until you remove the battery so I do that.
    nO PC told, so super hard to tell you tests to do, but the one above (bend test)
    NO PC told , NO PC told and NO PC told
    ALEX I'd like to try topic " What's my PC "at $500 please? Jeopardy! (RIP Alex !)
  • Anonymous Dec 05, 2021
    take it to a PC repair shop, and they fix it. 99% do that , why not you.
  • MaryMcCarthy
    MaryMcCarthy Dec 05, 2021
    [ JOIN US ] I get paid more than $60 to $70 per hour for working online. I heard about this job 3 months ago and after joining this I have earned easily $10k from this without having online working skills . Simply give it a shot on the accompanying site…
    Here is I started.……......>> http://Www.NETCASH1.Com
ADMIN Canada
    Top Expert:
  • Horizontal Master
  • 42,944 Answers
  • I can not see your screens failing, a huge problem asking the blind ,now?
    NO PC brand told
    no PC model told the 2007 models delivered to USA had bad GPU chip, (BGA solder ball ROHS failures)
    causes:
    bad LCD screen
    bad cable to screen
    bad GPU chip
    NO PC told, so super hard to tell you tests to do, but the one above (bend test)
Posted on Dec 05, 2021
3answers
Horizontal Lines appear across my laptop Dell InsironE1505
really? that would suggest a bad lcd or video chip...
Horizontal lines in lenovo r61
This is a indicator of defective LCD screen, the only option is replace the laptop monitor, go to www.ebay.com Type make and model of laptop, refine search to screen to get an idea of pricing.
Horizontal lines in laptop screen
Brand source customer service
Horizontal and vertical lines on ACER laptop
Hi there some how your laptop screen pressed & the screen is damaged. Just the option is replacing the screen. Another reason is over heating of screen by manufacturing default. Your laptop still under warranty so i suggest you visit the Acer service center & claim the damaged things if your screen does not have any over pressed symptom then. I hope you understand me. Thanks & waiting for your feedback.
Black screen with horizontal green lines
Hello yoyoxide.
from my experience can be something related with the video card. I recommend you the followig (Hardware diagnostics):
-Look for one of the discs that came with your computer, it should say (Drivers & utilities).
-Boot from the CD. If you don't know how to do it do the following:
1.Insert the Drivers&Utilities Disk.
2.Restart teh computer.
3. When you get the Dell logo, press F12
4.Select Boot from CD/CDRW-DVD (something like that).
-You will get a prompt to run the diagnosics.
-Just follow the wizard
-I recommend you to run diagnostics for everything.
-You will see if you have any problems with your hardware.
It seems that you have a pretty new laptop, so probably it's under warranty.
2answers
Lines on my laptop lcd
This is the most common errors/problems in lcd screen, create vertical or horizontal line. As i consult our resident electronic technician. he found out that the is a problem in vertical or horizontal projection panel board. The problems needs a series of testing and troubleshooting to shoot issue and resolve. So therefore your problem can be resolved only by personally servicing the unit. I suggest you to contact the vendor or the repairman in your area.
PS: pls do not rate me if my solution not solve the issue and you need more further information. but if is invaluable solution rate me fixya.
best regards, melnavz
2answers
Have multi colored horizontal lines in screen
Either your video cable needs to be re-seated,or your inverter is going bad.To fix either one you'll have to open your screens plastic housing and also remove the piecce of plastic where your power button is and lift out the keyboard.Re-seating the cable won't cost you anything,if you do it yourself.An Inverter will cost you roughly $60 plus shipping.
3answers
Moniter problem
the LCD screen is damaged.
hope this helps
Computers & Internet Logo
Top Horizontal Computers & Internet Experts
Ekse
Are you a Horizontal Computer and Internet Expert? Answer questions, earn points and help others
