Question about Hisense Televison & Video
My Hisense 55" Class - R6 Series, Model is 55r6e, HV550QUBH10, the problem I'm having is that the red light is blinking, and it's like the screen is dim and it's boot looping, and so I looked closer at the screen with a flash light, and the logo, is dim and so I started to look at the back, and I started to here like a static sound on the back so I got closer and it's making like a static and clicking sound behind the TV. Could this be the : T-Con Board?
Larry
  • Hisense Master
  • 3,898 Answers
No it will not be the tcon board clicking and if you see the logo that board is working. Your going to need to get some voltage readings from the power board and see if it's working ok for starters. Next would be unplug the backlight connector and see if the sound goes away, if it does you have bad backlights and I think this will be the issue
Posted on Dec 03, 2021
Testimonial: "thank you larry"
1helpful
3answers
Hisense 55R6E no picture /no sound
This model set had defective LED lamps from the factory and only lasted 1000 plus hrs...You can get lamps that will last from shopjimmy that will fix the issue for about $60 with shipping. Its not a hard job changing them, just takes some patience and care when handling the screen as it's extremely fragile on most lower price sets.
2answers
Where would the fuse be located on my 55 inch hisense tv
Unplug the TV's power cord and hold the power button directly on the tv ,keep holding it for 20 secs or so then let the tv sit unplugged for a couple of minutes before you try it again.
55 in Hisense has no picture, red start up light blinks three times when try to power on
Try software update google it for hisense dowload software to a memory stick and follow instructions
Hisense 55" Model # 55H6B electrical crash
Main digital board fault. Check and replace it. If you wish to get more details visit the site linked here. http://homenol. blogspot.com/ http://electronicshelponline.blogspot.com/
1helpful
I have hisense 55k20dg. Turns on, i have sound and picture but the brightness is extremely low and can barely see image unless room is completely dark,, would that be backlight inverter? Easy fix?
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electro-medical.blogspot.com/
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
I have a hisense 55k20dg and have no back lights but have sound and picture
MY HISENSE TV IS NOTT RESPONDING TO THE REMOTE CONTROL COMMANDS ALTHOUGH THE REMOTE IS BLINKING. MY REMOTE SERIES IS EN-31603 (IT CAME WITH THE LCD 32' HISENSE TV)
I have the same problem, NOTHING to do with batteries.BUT if you press the that blinking (red) button and hold it down and THEN press the option you want (channel +/-, volume +/- etc) the controls work. Im looking for an answer aswell to return it to its previous state where I dont have to do that!
My Hisense VIDAA TV 55" H7 Smart T.V. has about a 2 second lag in sound on live t.v. and recorded t.v. shows. How do I fix this?
Some TV,s have a sound delay that you can change. Try getting into the settings of the TV with the remote and look up audio, go into settings and see if there is a delay parameter that you can change.
Televison & Video Logo
Top Hisense Televison & Video Experts
Ekse
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Hisense Televison and Video Expert? Answer questions, earn points and help others
