I've (DWC-AD1222) Daewoo Washing machine front load 15Kg always gives me Error OE i've cleaned the hoses, pump filter, even i've changed the 2 motors of the pump, like logically i can't find a reason for it to stop draining and give the error code but it still do, PLEASE PLEASE PLEASE HELP!!!!
As these manufacturers use the same type board in their machines, video will help you
Daewoo Washing Machine Error Fault Code = OE
Fault Detected: Water Has Not Drained From The Washer
Washer Has Detected: The washing machine failed to drain water
Check / Repair / Fix = Drain pump - Wiring - Water level sensor - Connection to water valve
