Question about Samsung Televison & Video
I have a Samsung 55in UN55J6200AFXZA. Replaced everything. Still not working.
I replaced the backlight led array, tcon board, display board, and wifi card. All purchased from shop jimmy. I checked all the cables. Could I just have received a bad board?? The backlight 'does not' turn on when I disconnect the t-con board from the power supply board.
Posted by Shaun Nolan on
  • LindBrown
    LindBrown Dec 03, 2021
    [ JOIN US ] I get paid more than $60 to $70 per hour for working online. I heard about this job 3 months ago and after joining this I have earned easily $10k from this without having online working skills . Simply give it a shot on the accompanying site…
    Here is I started.……......>> http://Www.NETCASH1.Com
Larry
  • Samsung Master
  • 3,898 Answers
Board are tested before shipping at shopjimmy however things can happen in shipping and a good board can be damaged with improper handling. Best thing to do is run a few tests, start by testing the13volt rail on the power supply, this voltage is present on this set if it's plugged in. if this voltage is ok chances are power board is working. This model set has issues with the info from the EEPROM being corrupt. Without the equipment it's not something you can test I have a feeling you have issues with your main board and the one you received is bad or was damaged in shipping or handling, be at the TV when unpacking this board, take it from the anti static packing to the TV, anit static wrist bands are nice but not necessary if care is taken...do not unpack it in one room and carry it across carpet as it can be damaged. I'd have shopjimmy sent another board. One thing you didn't say is what was the original issue with your TV. Was it sound no picture, distored picture, standby lamp, dead...ect?
Posted on Dec 03, 2021
  • Shaun Nolan
    Shaun Nolan Dec 04, 2021
    I meant to update this last night. I reopened the tv and found a faulty connection on the led array. Installer error was the cause for my problem
    To answer your question. For months I had a dark spot on the bottom of the screen. The power supply board finally failed and the tv refused to start. But it's ok everything is working now. Thanks
Samsung UN65JS9000 - black screen with sound
Watch this video. It might help you.
https://youtu.be/mPkG-43RlXw?t=33
Samsung led tv quit working. Replaced all the boards inside, main, power, Tcon and WiFi. Still all i get is blinking red startup light
If one of the led lights in back light strip fails, the power supply senses the current change and shuts down. The LED strips have to be tested to see which one failed.
Samsung tv backlight problem
Replace the backlight inverter board.
I have a samsung Un55J6200afxza. sometimes when i power on the tv there is no backlight.
It could be a defective main board, or intermittent LED diode on the back lights strips.
I will try a new main board first.
2answers
UN55H6203AFXZA US01 turns on with sound but no picture. Flashlight test shows TCON is good. Back panel removed, TV on, no indication of backlight illumination. Standby light blinks 6 when turned on.
You're a technician work to earn I assume. Do understand; this is a forum to help one who knows a little; to make their sets right. Not a help you like people to turn revenue out of it. Understand? Do not know nothing; yet runs a service shop to cheat others!!!!! https://electronicshelponline.blogspot.com/
1helpful
TV Samsung 50 UN50EH5300FXZA BJ04. Sound but no picture. Replaced all boards, still no picture. Flashlight test saw image.
Hi Rick,
It appears to be a case of backlight failure. since you have replaced all the boards, inverter is ruled out. Some of the LEDs in the backlight array may have gone bad. Fault is repairable, but needs care and experience of opening and repairing the LED panel. Good luck.
Samsung Flat screen LED. has audio but no video.
Hi Frank,
Your TV has audio means the main board is working. You have not mentioned anything about the backlight. Most probably the backlight is not working in your case. If it is so, it is either some failed LED or LEDs in the array or a failed driver on the power board. Please check the drive voltage for backlight in on condition to confirm the inverter.
Open Questions:
Televison & Video Logo
Ekse
 Francisco Mauricio...
