Television shuts down on it's own, and start it up again. It runs for about 90 seconds, then shuts down again. I have tried several times with same result.
Posted by Fred park on
  • LindBrown
    LindBrown Dec 03, 2021
    [ JOIN US ] I get paid more than $60 to $70 per hour for working online. I heard about this job 3 months ago and after joining this I have earned easily $10k from this without having online working skills . Simply give it a shot on the accompanying site…
    Here is I started.……......>> http://Www.NETCASH1.Com
Larry
  • Televison & ... Master
  • 3,898 Answers
Your going to need some voltage readings to fix the set as it could be several different issues causing this, best chance is bad power board but it could be other issues as well
Posted on Dec 03, 2021
Computer shuts down on its own. First it starting
Could be HArd disk drive issue or Windows OS issue, try repair windows operating system before you change your hard disk drive , good luck
Hl72a650
color wheel issues replace light engine
Flat panel TV comes on by it's self
It sounds that the voltage output from its internal power regulator board is not proper. Check it.
Pc won't start
Think your power supply died. Check that out first since they are relatively inexpensive. Or throw in a known working PS to see if that does the trick. Write back with results for further info.
Gateway Profile 5.5 Randomly Shuts Down
it seems, You can try after disabling firewalls. please let me know the results. I can guide you.
Kenmore Elite QuietPak 2 powers up and shuts off within seconds
I need the serial #, to better assist you
Thank you
Compaq Presario SR1123WM PC Desktop will not start up.
try starting it in safe mode, when click the power bottom press f8 repetitively then select safe mode. then restart it again.
1helpful
Samsung hcm4216w won't turn on light blinks then shuts down and tries to restart again
Your problem is TV is not getting enough power so you better buy a stabilizer and make the power to go thro the stabilizer to TV then it will get sufficient power supply everything will be smooth afterwards even the voltage problem.
H.V shuts down/
try to check a bad conections in hv transformer and capacitor around them
Televison & Video Logo
Top Televison & Video Experts
Ekse
