My Seiki SE50FYT TV shuts off after 40 seconds.
It worked perfectly until yesterday. Then after it boots, it runs for about 35-40 seconds and shuts off. Even if repeatedly turning it on it follows this pattern. Any suggestions?
  • Anonymous Dec 06, 2021
    post to TELEVISION not computer repair help
    here
    https://www.fixya.com/troubleshoot/seiki...
    sure, why not asssume its overheats first (no spare part needed here)
    and blow it out , all vents and dust there and inside all dust blown out
    so it can stay cool and not overheat and shut down,
    or get it serviced in a , (Drum roll) TV repair shop.
A Kisling
    Habit-Forming:
  • 100 Answers
Seems to be a power issue.
-Overheating
-Short some where in the circuit
-Outlet Issue
Would advice the get a Tech so check/follow the power & check outlets.
AK
Posted on Dec 06, 2021
1helpful
TV screen goes blank just after switching on; volume stays on. After examining circuit boards, discovered immediately selecting menu then reset to default my screen operates perfectly until off.
It sounds to me that it is possibly in another mode ie. PC, HDMI, etc. and when reset to default goes to tv, but once turned off, goes back to the other mode. I would suggest going to menu and instead of going to default, go to TV and set it for that mode. You may have to do this very quickly upon startup before it goes to another mode.
1helpful
Seiki 39 inch 4k lcd tv turns off after 10 to 20 min.
A lot of times a set that turns off after being on awhile is capacitor issues, pull the back and see if any look swollen or bulged
No sound on tv seiki 40 in
Hello
Sometimes, someone accidentally turns off the sound - check your settings and if you have external speakers, unplug them, switch off your TV and unplug everything, wait for 10 seconds and then plug it back in and restart it to check if this makes a difference; try some external speakers as well if they are available to you. Still nothing, call the manufacturer's helpline.
ilona
Toshiba Qosmio F25-AV205 screen keeps going black
If your laptop appears to boot up and the hard disk LEDflashes, then the problem is probably a back light fault. This can be a faultyinverter or a faulty CCFL lamp. Please click on this link and follow myinstructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Gateway 5056 Media center doesn't boot everytime.
did you look on gateways website for a bios update. the firmware on your motherboard maybe corrupt. go here and check since I dont have your serial number... gateway has a java based scanner that might be able to repair it for you
http://support.gateway.com/support/drivers/dlcenter.asp
please rank me if you can
Screen Goes Green TV goes to stand by blinking 8 times
try adjusting your color tuners located inside tv behind speakers.
Computers & Internet Logo
Ekse
