Televison & Video Logo
Question about Toshiba Televison & Video
My Toshiba Smart TV is only 2 years old and keeps switching channels on its own.
All of a sudden its changing channels on its own. If I leave it like that, after a while a red timer appears for about 1 min, then the tv turns off. Then it comes on itself and does the same thing with the channels. Please help.
Posted by Millicent Freeman on
ADMIN Andrew
    Top Expert:
  • Toshiba Master
  • 57,483 Answers
I would guess it is either overheating, or someone has a Samsung next door and your remotes are the same. :>/
For overheating, go around the back and side vents with a vacuum cleaner with the small brush attachment on it.
Posted on Dec 03, 2021
Toshiba TV channels keep changing on their own
Your EEPROM has some bad files on it. It's an expensive IC to chance if you have the equipment and knowledge to replace it, other option is replace the main board
Hi I have a THORN hd smart tv 55' turns on but then just black screen sound is fine can change the channel but can't see a thing tried unplugging it holding power button down for 60 sec
I have a 55inch thorn TV not a smart TV Tho n it keeps randomly turning off day and night n once it flicked from hdmi channel to normal TV channel, no set some or anything I'm worried a fault or boogidy, it's bout 5 or 6 years old n only been doing it the last week ??
Toshiba smart tv stuck on one channel tried new remote wont change channel went back to old remote still the same
Did you try changing the source? It might be getting the channel from a source other than the TV.
1helpful
My tv keeps changing channels on its own. I have taken the batteries out of the remote and tried using tv only but it still does it. TV is only 3 years old
Will you check the channel button at the side of your television if the button will normaly press on.If not,the problem is in the system of your TV.Ethier the system ic is deffective.Its better to repair the authorized technician.
Toshiba t/v model 155R9B how to set channels to correct numbers The channels are coming up to the wrong nos. for instance BBC1 could be on no. 3. how do i set them to correct channels?
Digital tv channels use analog carrier frequency of old system then changes to digital tv numbers later in the tuner memory. Leave tv on or standby at all times to have tuner set the digital tv numbers in its memory. You can reset the memory by pull the plug on the wall for 5 minutes then reconnect to the wall plug.
1helpful
Only the lower channels work
Sounds like somehow the TV got switched from Cable to Antenna.
If there is a Menu look for a way to switch it back.
If it is REALLY old there may be a Cable/Antenna toggle switch on the back of the TV. If so, put it in the Cable position.
Tv combo is 2 years old..only use in bedroom. very little use..push the button on tv or remote, the tv comes on for a second,,then goes off..if i turn on tv with remote, and keep the button held down,,the...
This is a very common problem in these sets. I would recommend taking it to a certified repair shop. What normally happens is that the x-ray protect transistor starts to "leak" (electricity, not fluids) and shuts the unit down. The repair is not too costly.
My Phillips SLC4 flat screen TV has suddenly
The problem has cleared itself a day later after being switched on/off a few times.I suspect the 'computer part' of the TV (channel processor, instruction decoder etc) received maybe a power glitch or an illegal infrared instruction (2 remotes used at once for example) and 'locked up' leaving just the analogue side operating.
I was going to continue happily using it with just the analogue side slaved to my Hd recorder for digital signals but it seems to have got over whatever it was that upset it.
Toshiba 51h85c rear projection screen is red!!
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
