Miscellaneous Logo
Mark Page Posted on Dec 02, 2021
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Is there a diagram for the wiring of a CZ310RBL Climate Keeper reversible window fan?
My new fan quit working. I replaced the 5A 125V fuse (tried 2 to make sure) and it still wasnt working. I opened it up amd there is a dark burgundy wire that isnt attached to anything other than the top control panel.
David Shaub
Level 3:
President:
  • Master 2,994 Answers
  • Posted on Feb 19, 2022
David Shaub
Master
Level 3:
President:
Answers
2994
Questions
Helped
1153376
Points
8370
There is a good chance, the fan just needs oiled, where the shaft goes into the motor.
SHENG CAI
Level 1:
Habit-Forming:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 12 Answers
  • Posted on Feb 03, 2022
SHENG CAI
Contributor
Level 1:
Habit-Forming:
Welcome Back:
Answers
12
Questions
0
Helped
1291
Points
26
The powerful, dual-blade Bionaire Twin Reversible Airflow Window Fan has routinely clobbered every other window fan we've tested, and many members of Wirecutter's staff have happily used this model for years. However, we've seen new complaints pop up with this model in recent summers, noting some problems that we've experienced ourselves in re-tests. Window fans meet a unique need, but they are notoriously weak products. So even though this is the best of the lot, those who are shopping for a window fan should ask themselves whether they need to get one in the first place.
2007 Pontiac Solstice convertible. The sound through speakers quit?
Fuse or Relay Number Fuse Rating Protected Component 1 40A Body control module - battery power in feed 1. 2 20A Power outlet main console bin. 3 40A Body control module - battery power in feed 2. 4 30A Fuel pump. 5 5A Powertrain control module keep alive power. 6 20A Powertrain control module power. 7 20A Canister vent solenoid. Evaporative leak control module. Exhaust gas heat recovery (hybrid electric vehicle). Tank pressure control valve (hybrid electric vehicle). Vapor blocking valve. Universal exhaust gas oxygen 11. Universal exhaust gas oxygen 21. Catalyst monitor sensor 12. Catalyst monitor sensor 22. Fuel flap door (hybrid electric vehicle). 8 20A Cooling fan relay coil. Battery interrupt box. Transmission oil pump. Auxiliary coolant pump. Engine coolant bypass valve. Electric A/C compressor (hybrid electric vehicle). Active grille shutters. 9 20A Ignition coils. 13 40A Front blower motor relay. 14 15A Transmission oil pump. A/C compressor variable clutch. Auxiliary pumps (hybrid electric vehicle). Electric A/C compressor (hybrid electric vehicle). Active grille shutters. 16 15A Windshield and rear window washer pump relay power. 17 5A Charge status indicator (hybrid electric vehicle). 18 30A Starter motor. 21 10A Headlamp red and blue flasher. 22 10A Electric power assisted steering module. 23 10A Anti-lock brake system module with integrated park brake. 24 10A Powertrain control module. Hybrid powertrain control module. 25 10A Air quality sensor. 360 camera with park aid. Rear view camera. Blind spot information system. Adaptive cruise control module. 26 15A Transmission control module. 28 40A Anti-lock brake system valves with integrated park brake. 29 60A Anti-lock brake system pump with integrated park brake. 30 30A Driver seat module. 31 30A Passenger seat motor. 32 20A Front media bin power point. 33 20A Rear cargo area power point. 34 20A Console end cap power point. 35 20A Console end cap power point. 36 40A Power inverter. 38 30A Climate controlled seat module. 41 30A Power liftgate module. 42 30A Trailer brake control module. 43 60A Body control module. 44 10A Brake on and off switch. 46 15A Battery charger control module (hybrid electric vehicle). 50 40A Heated backlite. 54 20A Visor control module. Run/start access feed. 55 20A Trailer tow park lamps. 57 30A Trailer tow battery charge. 58 10A Trailer tow backup lamps. 61 15A Not used (spare). 62 15A Headlamp washer pump. 64 40A Four-wheel drive module. 69 30A Front window wiper motor. 71 15A Rear window wiper motor. 72 20A Not used (spare). 73 30A Driver door module. 78 - Not used. 79 - Not used. 80 20A Not used (spare). 82 20A Not used (spare). 88 20A Rear blower motor. 91 20A Trailer tow lighting module. 95 15A Integrated spark control (hybrid electric vehicle). 96 15A Not used (spare). 97 10A Electric AC (hybrid electric vehicle). High voltage positive temperature coefficient heater (hybrid electric vehicle). 98 10A Traction battery coolant proportional valve (hybrid electric vehicle). 103 50A Rear power lug. 104 50A Rear power lug. 105 40A Not used (spare). 106 40A B+ feed. 107 40A B+ feed. 108 20A Spot lamp. 109 30A Passenger door module. 111 30A Body control module voltage quality monitor feed. 112 20A Not used (spare). 114 50A Not used (spare). 115 20A B+ feed. 116 5A Start access circuit. 118 20A Run/start feed. 120 15A Port fuel injectors. 124 5A Rain sensor. 125 5A USB smart charger 1. 127 20A B+ feed. Rear traffic advisor. Visor control module. 128 15A Not used (spare). 131 - Not used. 133 - Not used. 134 10A Delay accessory power. 136 20A Not used (spare). 139 5A USB smart charger 2. 142 5A Traffic cam. 146 15A Battery electronic control module. 148 30A Left-hand headlamp module. 149 30A Right-hand headlamp module. 150 40A B+ feed. 155 25A Transmission control module (hybrid electric vehicle). 159 15A DC/DC converter (hybrid electric vehicle). 160 10A B+ feed. Front warning lights. Strobes. 168 20A Low voltage service disconnect. 169 10A Coolant pump (hybrid electric vehicle). 170 10A Traction battery coolant pump (hybrid electric vehicle). Pedestrian sounder (hybrid electric vehicle). 177 10A Not used (spare).
Note: Spare fuse amperage may vary.
Passenger Compartment Fuse Panel
The fuse panel is under the instrument panel to the left of the steering column.
Note: It may be easier to access the fuse panel if you remove the finish trim piece.
Fuse or Relay Number Fuse Rating Protected Component 1 - Not used. 2 10A Moonroof. Inverter. Telematics control unit module. Driver door switch pack. 3 7.5A Memory seat switch. Wireless accessory charger module. Seat switches. 4 20A Not used (spare). 5 - Not used. 6 10A Not used. 7 10A Smart data link connector power. 8 5A Telematics control unit module. Hands-free liftgate actuation module. Power liftgate module. 9 5A Keypad switch. Rear climate control. 10 - Not used. 11 - Not used. 12 7.5A Climate control head. Gear shift module. 13 7.5A Steering column control module. Smart datalink connector. Instrument cluster. 14 15A Not used (spare). 15 15A SYNC. Integrated control panel. 16 - Not used. 17 7.5A Headlamp control module. 18 7.5A Steering wheel interface. 19 5A Headlamp switch. 20 5A Ignition switch. Telematics control unit module. Key inhibit solenoid lock. 21 5A Not used. 22 5A Not used (spare). 23 30A Not used (spare). 24 30A Moonroof. 25 20A Not used (spare). 26 30A Not used (spare). 27 30A Not used (spare). 28 30A Not used (spare). 29 15A Integrated computer screen. 30 5A Brake switch signal. 31 10A Terrain management switch. Selectable drive mode switch. Transceiver module. 32 20A Audio control module. 33 - Not used. 34 30A Run/start relay. 35 5A Low gear select. 36 15A Park assist module. Image processing module A. 37 20A Not used (spare). 38 30A Left-hand rear power window. Right-hand rear power window.
1helpful
Why would my climate control fan quit operating?
It may be a fuse, you would have to check your fuse box. I would check the fan itself. Whether an old fan or a new fan , ware does occur sometimes fast sometime it takes years. Check fan buy moving fan shaft up and down ,side to side. if it moves fan bushings are bad. Sometimes you can repair if your capable, but most times you just replace the fan. GOOD LUCK FRIEND.
12helpful
3answers
IM IN NEED OF A FUSE BOX DIAGRAM FOR A 1999 LINCOLN NAVIGATOR
go to the ford lincoln mercury website and enter you year, make, model of your vehicle. It will let you download a pdf version to your computer. then open the document and go to page 135. this is free don't pay for something you shouldn't, you already got the vehicle. this is just information. Fuse Location,Fuse Amp,Description
1) 25A Audio
2) 5A Clock, Overhead Trip Computer, Electronic
Automatic Temperature Control (EATC),
Powertrain Control Module (PCM), Cluster
3) 20A Cigar Lighter, OBD-II Scan Tool Connector
4) 15A Autolamp Module, Remote Entry Module,
Mirrors, Memory Module, Adjustable
Pedals, Air Suspension Switch
5) 15A AC Clutch Relay, Speed Control Module,
Reverse Lamp, EVO Module, Climate Mode
6 5A Cluster, Overhead Trip Computer, Compass,
Steering Sensor, Brake Shift Interlock
Solenoid, Air Suspension Module, GEM
Module
7 5A Aux A/C Blower Relay, Console Blower
8 5A Radio, Remote Entry Module, Cell Phone,
Clock, GEM Module
9 — Not Used
10 — Not Used
11 30A Front Washer Pump Relay, Wiper Run/Park
Relay, Wiper Hi/LO Relay, Windshield Wiper
Motor, Rear Washer Pump Relay
12 — Not Used
13 20A Stop Lamp Switch (Lamps), Turn/Hazard
Flasher, Speed Control Module
14 15A Rear Wipers, Running Board Lamps,
Battery Saver Relay, Interior Lamp Relay,
Accessory Delay Relay (Power Windows,
Flip Windows, Audio)
15 5A Stop Lamp Switch, (Speed Control, Brake
Shift Interlock, ABS, PCM Module Inputs),
GEM Module
16 20A Headlamps (Hi Beams), Cluster (Hi Beam
Indicator)
17 10A Heated Mirrors/Rear Window Defroster
Indicator
18 5A Instrument Illumination (Dimmer Switch
Power), Clock (Dimmer)
19 — Not Used
20 5A Audio, Four Wheel Air Suspension (4WAS)
Module, Memory Module, GEM Module,
Digital Transmission Range Selector
21 15A Starter Relay, Fuse 20
22 10A Air Bag Module
23 10A Electrochromic Mirror, Aux A/C, Heated
Seats, Trailer Tow Battery Charge,
Turn/Hazard Flasher, Console Blower Door
Actuator
24 10A Climate Mode Switch (Blower Relay),
EATC (via fuse 7), EATC Blower Relay
25 5A 4 Wheel Anti-Lock Brake System (4WABS)
Module
26 10A Right Side Low Beam Headlamp
27 5A Foglamp Relay and Foglamp Indicator
28 10A Left Side Low Beam Headlamp
29 5A Autolamp Module, Transmission Overdrive
Control Switch
30 30A Passive Anti Theft Transceiver, Cluster,
Ignition Coils, Powertrain Control Module
Relay
31 10A Rear Integrated Control Panel (Audio), CD
Player, Cell Phone
Relay 1 — Interior Lamp Relay
Relay 2 — Battery Saver Relay
Relay 3 — Rear Window Defroster Relay
Relay 4 — One Touch Down Window Relay
Relay 5 — ACC Delay Relay
hope this helps.
2answers
Fuel Pump Fuse Number for a 1998 audi a4 2.8 quattro
Fuses: Fuse arrangement in fuse panel, behind instrument cluster, left
Fuse Arrangement In Fuse Panel 62624464
1 - Heated washer jets 5A 2 - Turn signals 10A 3 - Headlight washer (relay), illumination for glove
compartment, climate control, Automatic Transmission, instrument cluster 5A 4 - License plate light 5A 5 - Instrument cluster, seat heating, test connection
for cruise control, bulb monitor for auto-check display, Automatic Transmission display, switch
lighting, mirror switches and actuators, airbag
warning light, outside temperature indicator,
climate control 10A 6 - Central locking system 5A 7 - Anti-lock brake system (ABS) 10A 8 - Vacant 9 - Mirror heating 10A 10 - Vacant 11 - Cruise control (Automatic Transmission) 5A 12 - On board diagnostic system 10A 13 - Brake lights 10A 14 - Interior lights, reading lights, anti-theft alarm system, vanity mirror 10A 15 - Instrument cluster, power windows, climate control, automatic transmission 10A 16 - Anti-lock brake system (ABS), Anti-Slip Regulation (ASR) 5A 17 - Heated door locks 10A 18 - High-beam, right 10A 19 - High-beam, left 10A 20 - Low-beam, right 15A 21 - Low-beam, left 15A 22 - Side marker and tail light, right 5A 23 - Side marker and tail light, left 5A 24 - Wiper and washer system 25A 25 - Blower for heating, climate control 30A 26 - Rear window defogger, mirror heating 30A 27 - Rear window wiper 15A 28 - Fuel Pump 15A 29 - Engine timing 30A 30 - Sun roof 20A 31 - Tail lights, cruise control, automatic transmission 15A 32 - Engine timing 20A 33 - Cigarette lighter 15A 34 - Engine timing 15A 35 - Trailer recptacle 30A 36 - Fog lights 15A 37 - Radio 20A 38 - Luggage compartment light, central locking system 15A 39 - Emergency flasher system 15A 40 - Horn 25A 41 - Anti-lock brake system (ABS) 25A 42 - Vacant 43 - Vacant
4helpful
Where can I find the internal fuse on the GE Monogram Hood model ZV950SDSS?
There are (2) inline 5A - 125V fuses under the top fan/duct cover. They are located on the left side (as facing the unit) in a plastic junction box. Four Phillips head screws hold the cover on.
18helpful
2answers
Pioneer sd-643hd5 fuse issue
The fuses may not be your problem--I have fixed several of these---The large power board is on the right side as you look from the back?
Lots of these sets develop bad solder connections on that board--several sites on the internet offer to have you remove and send them the board to resolder--this set used lead free solder and after some years has problems--a few I have opened had clearly broken solder joints--I usually in this case remove the board(mark all the many plugs and make a diagram) and solder almost all of it by hand----usually fixes this kind of trouble.
I do this here for free so if this information was helpful give me a vote here....I am here to help people.
If you have any questions or need advice reply to this posting here.
SD TECH
Mitsubishi WT-46809 Powers Off; Code 2-2
The 2 fuses you mentioned are associated with the convergence IC. If they are open then the convergence IC is either bad or you have a "cold" solder joint on the IC.
Indentifying fuse type on tac0151 chassis
Are just regular fuses 5A/125V. You can replace them with anytype 5A fuses.
Toshiba 50H81 TAC0151 Blowing Fuses, I Need schematic
Well without the schematic, knowing Toshiba they have alot of convergence problems, so see if the fuse blown in the convergence area, if you you may have to replace convergence amps. These are the big STK's. Most of the time there was a color problem with set before going out. If no problem with this on your set then look in the HV area Hor. and Ver. area. Hope this helps!
Top Miscellaneous Experts
H Smith
Level 1 Expert
Robert
vince
Are you a Miscellaneous Expert? Answer questions, earn points and help others
