Question about Canon PIXMA MX892
Canon MX892 printhead bad?
How to clean the print head?
Posted by dennis lee hixon on
Mehandi Husain Suleman
  • Canon Master
  • 1,654 Answers
Hi
find link for how to clean the printer head
https://www.youtube.com/watch?v=ZGElrMuU8m4
Posted on Dec 02, 2021
7answers
Canon MP276 show a error number B200. How I solve it?
Try removing ink cartridge and see if the error goes away. If it does, you have a bad cartridge. Sometimes that happens to new cartridges as well. When your printer shows a b200 error, the ink carrier will not move, so you have to gently move it to where you access cartridge to remove it. This is for all canon printers that have a 2 cartridge ink system. For printers with a removable printhead, see solution below:
How do you remove the printer head to clean it?
Regarding your recent inquiry about your MX892 poor print quality/lack of printing performance (or similar), it sounds like your PRINTHEAD is either clogged (from dried ink) or has reached END-OF-LIFE, to help determine which please perform the following steps (if you have already performed a step, please continue to the next step in the order shown):
Canon Cartridge Troubleshooting: http://inkjet411.com/?page_id=1537
1.Go into the printer\'s maintenance/tools menu and print a print quality test (i.e. heading cleaning, nozzle test or similar) to help identify which color (of number of colors) is impacted.
NOTE: To help determine which color has run out, use the following suggestions in sequence until you are able to identify the empty color:
1) Generate a Print Quality Test Page from your printer control panel; a faded color band indicates empty. 2) To distinguish between a black and photo black cartridge, print a text document and/or a photo. Faded black in a text document indicates the black cartridge is empty; faded black in a photo indicates the photo black cartridge is empty. 3) To distinguish between cyan, yellow, and magenta click here: http://inkjet411.com/?page_id=146 A faded or missing color band indicates empty.
2.At the printer\'s control panel under the \'Maintenance\' or \'Tools\' menu, activate a \'CLEANING\' or \'HEAD CLEANING\' to prime the ink system. Then Run the Inkjet411 \'Ink Recovery Test Print\' from our Test Prints page to verify all colors are firing properly (all printers also provide some form of a Self Test page): http://inkjet411.com/?page_id=146
3.Check your user\'s manual to see if there are any procedures on cleaning the service station/capping station assembly (this is where the carriage/cartridges \'park\' when not in use). A dirty service station can cause all kinds of improper color output problems (assuming the printhead is working correctly of course). NOTE: May not be applicable for your model depending on the printer design.
4.If this does not remedy the problem, then one or more of the ink ports may be dry within the PRINTHEAD assembly (the ink cartridges physically connect to this electronic assembly). We suggest you either remove the printhead and perform a hot water flush for 2 minutes (in a sink) or using an eye-dropper, or similar, drip 5-10 milliliters (i.e. 1-2 teaspoons) of distilled water into the respective color ink port to help saturate the foam. http://inkjet411.com/?page_id=2804
7.Reinstall ink cartridges and retest.
      Inkjet411 Suggested PRINTHEAD Cleaning Procedures:
      Canon Printhead Warm-Water Flush Procedure: http://inkjet411.com/?page_id=2804
      3rd party PRINTHEAD CLEANING solutions (for additional reference only):
      http://www.youtube.com/watch?v=FL8QaFVwsEs(Canon)
      http://www.youtube.com/watch?v=ZheZf-vdho8 (Canon Printhead removal / water flush)
      8.If the problem persists, then you may have a damaged PRINTHEAD (worst case scenario), unrelated to the refilled cartridges. The printhead is a separate electronic assembly (which the cartridges are installed into) and is responsible for firing the ink drops onto the paper. Over time and based on usage this assembly will eventually fail (typically lasts ~4,000 to 5000 printed pages on avg). Refer to video on how the PRINTHEAD functions: http://inkjet411.com/?page_id=2054
        PRINHEAD TECHNICAL NOTES:
        IIT (individual ink tank-based) printer models have an electronic PRINTHEAD within the base of the carriage assembly (responsible for pulling ink from the 4, 5 or 6 ink cartridges and then firing the ink droplets onto the paper) - these will eventually fail depending on print usage type and printer duty cycle (i.e. rated for approximately 10,000 printed pages over life, but the consumer average is typically closer ~4,000-5,000 thruput pages). The printhead is replaceable and can be ordered directly from the manufacturer or www.Amazon.com . For information on how the PRINTHEAD functions, please watch the following video: http://inkjet411.com/?page_id=2054
        Typically the printhead should not reach it\'s end-of-life until after a minimum of 8 or more complete sets of cartridge changes. While some printheads may last 10,000+ pages others may only last 2000 pages, actual results will vary. The printhead will eventually fail in time due to an internal micro-electronics failure, due to the following leading factors: general customer print usage and printer care, printer duty cycle (i.e. # pages printed per month), printing frequency (i.e. time between each print job), print mode (i.e. draft vs. normal) and content printed (i.e. photos vs plain pages) and color mode (black and white only vs. color/greyscale printing).
        Paper types used (i.e. plain paper, photo papers & matte/heavy bond papers) and paper edge curl (i.e. duration in printer and/or exposure to low relative humidity) can also quickly lead to premature printhead failures due to physical \'head strikes\' of the paper edges making repeated contact with the printhead nozzle plate surfaces.
        For any additional questions please contact us directly: [email protected]
        NOTE: If you need to purchase a new ink cartridge(s), we suggest you try a remanufactured ink cartridge from http://www.inkplicity.com/ as their ink cartridges typically have the lowest cost in the USA and have a high reliability rating.
        -Thank you
Canon mx892 shows error code B200: Printer error has occurred. Unplug the power cord and contact the service center
The fault in Canon Printer Error Code B200 indicates a defective print head. A print head is a component that directly collects the ink onto the paper from the cartridges, which means it's one of the most critical parts of the printer.
Canon Printer Error Code B200, which can signify a hugely damaging system error, is one of the most feared.
Want to Correct the B200 Canon Printer Error Code?
1. Unplug and leave your printer disconnected for a minimum of 30 minutes.
2. Open your printer's door and you can move the print head so you can reach it.
3. Take off old ink.
4. The complete Canon Printer Error Code B200 solution.
Check this Blog - Canon Printer Error B200
How do i remove and clean the printhead from a canon pixma mp780?
Hi there. i understand that you want to clean the printhead of your canon pixma mp780, dont worry im here to help you out with this.
do this following steps in order for you to clean the printhead.If the printed Nozzle Check Pattern is broken, missing, or a specific color is not printed, clean the print head.
  1. Press the <Menu> button on the printers operation panel repeatedly until [MAINTENANCE] appears in the LCD.
  2. Press the left [<] or right [>] arrow buttons to select the cleaning setting you want. Select [HEAD CLEANING] or [HEAD REFRESHING] for deep print head cleaning.
    Take Note: [HEAD REFRESHING] uses more ink than [HEAD CLEANING], so perform [HEAD REFRESHING] only when necessary ok?
  3. Press the <OK> button.
  4. Print a Nozzle Check Pattern and perform at least two Head Refreshings if the pattern is not correct.
hope that this steps helped you a lot in cleaning the printhead of your printer.Good Luck!
I have a canon i960 printer. It won't print blue. All other colors work fine. I've replaced the ink, downloaded new drivers, run the clean print head utilities, both regular and deep cleaning. What do...
I would guess that the printhead is bad. Google cleaning printheads or get a new one. Sometimes , not always you can clean the printhead instead of replacing. (take out and clean by hand)
2answers
Black ink does not print. Color works fine.
The print head is probably blocked then. You may be able to get a cleaning cartrige if you look online. Failing that, it will probably need a service.
1helpful
Canon MP730 not printing. Printhead cleaning doesn't help.
You may need new print heads. They are around $50. Or, you could do this: Take the print head out of the printer, and run warm water from the tap (not high pressure), over the ports for about 5 minutes. Ink will drop out of the jets. Dont touch the electrical contact end of this head. This may clean the head enough so it works again. If not you need a new print head.
Every other line printing poorly
your machine is getting on in age a bit now sounds as it needs a new print head, if you remove the printhead and physically give it a good clean and replace back in machine and do a head clean and your prints are still bad you need a new printhead
Canon Tech
Canon PIXMA MX892 Logo
old marine
old marine
Ekse
