Question about Command Computers & Internet
My Fusion 5laltop is stuck at a blue screen and I can't boot up my laptop?
What command prompt do I type in boot up menu when I get into start up screen?
  • Anonymous Dec 02, 2021
    no pC told full model , no OS told, ?
    Fusion 5 laltop
    in w10 (IS IT) hard cold power on boot the PC 3 times and magical w10 self repair runs and fixes the problem
    no OS told making answer 100 times more hard.
    just blue, no words, no BSOD codes,?
    windows 10 has over 100 BSOD codes.
    most laptops fail for batteries dead. 99% but is based on age, and no model real told
    so I can not measure age, that matters most of all things made by man.
    turn over the Laptop, see tag see Fusion 5 lapbook T90B pro? 2016 made? if yes, battery can be bad.
    names like that have deep meaning but to me it is AGE
    a90b
    or what?
    cheap (dirt) laptop seller says what more can you ask for.
    answer support zero
    books on it zero. (no service manual , bad to the bone.
    no web site support found. bad bad bad.
    the reviews show this
    Built by Fusion5, a UK-based hardware maker
    so is a UK maker that buys generic PC from china and brands them with FUSION< how cute?
    what we do this.
    the 3cold boot tricks w10, at blue screens of *****.
    then if fails
    remove the huge battery and run on AC power pack only
    we then run HDD tests if the OS runs now, ask, smart tests takes 15 seconds to run.
    this cheap PC has no built diagnostics. like all dells have. (pay more get more and fulls support)
    do you have unbacked up data there? y/n?
    if not reload windows and reboot? but will fail if hdd is bad. smart test fail is that.
Mehandi Husain Suleman
  • Command Master
  • 1,654 Answers
Hi
A blue screen error may occur if the BIOS or a device driver is out of date or is not compatible with some other hardware or software component. Try updating the BIOS and device drivers to resolve the problem.
Posted on Dec 02, 2021
I am stuck in Safe mode with command prompt on my Dell 620 laptop windows xp every time I type a command it says it is not recognized as an internal or external command, operable program, or batch file....
try restarting the laptop and before anything pops up on the screen hit the f8 key and the boot menu comes up then start in last configuration that worked and see if it helps
MY COMPUTER SCREEN IS SHOWING BLUE
This is more than likely a fault in the operating system, if you can boot in safemode you can try running a restore
To do this
1. boot in safemode with command prompt
2. when cmd comes up
3. type rstrui.exe
That will guide you through what you need to do.
If that fails then try typing into that command prompt :
chkdsk /r /f
(if your on xp TRY : fixboot)
If your still getting the bluescreen im afraid you will have to reformat your pc which means you will lose your data so get a backup if you can get into safemode.
Matt
HP Centario running Lenux I reset the CMOS battery and the blue screen still comes on says password required what am I doing wrong?
if you are running linux ubuntu
http://www.howtogeek.com/howto/linux/reset-your-forgotten-ubuntu-password-in-2-minutes-or-less/ Click "Applications" and then click "Accessories" on the top taskbar in the Ubuntu desktop. Click "Terminal" to open a terminal window. Type the following command at the Linux prompt and press the "Enter" key: sudo passwd To change the Administrator account password, the password of "root" is changed. The "sudo" command gives the current user temporary Administrator access, in this instance, to change the password of "root." First, the user will see a Unix prompt asking for the current user's password. Type the user password for the current user account. Press the "Enter" key. Next, Unix will prompt the user for the new password for "root." Type the new password for "root." Press "Enter." Finally, a Unix prompt will require a confirmation of the password. Retype the new password for root, and press "Enter." The Administrator (root) account password for Ubuntu is now reset or Boot computer into recovery mode. Reset your computer and as it is booting, hold down the "Shift" key on your keyboard. You will be presented with the boot menu. Select "Recovery Mode" from the boot menu. It is usually the the second boot option. Wait for computer to boot up. You will be presented with the Recovery Menu. Select "Drop to Root Shell Prompt." Type "ls /home" and press "Enter." Note: The command starts with a lower case L, not a capital i. You will be presented with a list of usernames of accounts installed on the computer. Type "passwd username" where username is replaced by the name of the account you want to reset. For example, if the username of your account was "jeff" you would type "passwd jeff" and press "Enter." You will be prompted to create a new password. Enter a new password of your choosing. Note: You will see no visual response when you type in your newly selected password; however, the computer still will register the input. Press "Enter." You will be asked to retype your password. Re-enter the same password and press "Enter." Your password is now reset. Type "Exit" to return to the boot menu and select "Resume Normal Boot" to restart Ubuntu.
It is stuck in a loop the screen goes from the IBM logo to a screen explaining that windows didnt start successfully to windows starting up to a blue error screen and then repeating.
You can have your T42 working again by doing the following:
1. In the windows didnt start succesfully screen choose to boot in safe mode with command prompt
2. when it starts, enter the command chkdsk (that means check disk)
3. accept all the changes done by running the command above and restart your laptop
4. everything should be OK now
1helpful
This what my laptop says, it says ***stop: 0x000000ed (0x812ace30, 0xc0000006, 0x00000000, 0x00000000) that is the technical information on the blue screen unmountable boot volume and i dont...
To repair follow these steps:
  1. Start your computer by inserting the Windows installation disk if your computer can start from the CD/DVD drive.
  2. When the Welcome to Setup screen appears, press R to select the repair option.
  3. If you have a dual-boot or multiple-boot computer, select the Windows installation that you want to access from the Recovery Console.
  4. Type the administrator password when you are prompted to do this.
    Note If no administrator password exists, press ENTER.
  5. At the command prompt, on the drive where Windows is installed, type chkdsk /r, and then press ENTER.
  6. At the command prompt, type exit, and then press ENTER to restart your computer.
  7. After you repair the volume, check your hardware to isolate the cause of the file system damage.
Booting from the Dell CD that came with my laptop. No good, I never get to the menu. My computer starts booting from the CD, I get the screen where it says 'Windows is loading files' and the white bar....
press F12 at boot time and select to boot the Diagnostics, in there let it run through the diagnostics and see if you get any error codes.
If this is clean then try booting windows into safe mode by pressing F8 as the computer boots up, then select to boot into Safe mode with command prompt and at the command prompt type chkdsk /r let it finish and try booting your system again.
also make sure you are booting the CD by pressing the F12 key at bootup and select the CD/DVD drive as the boot source. You may be inserting a non bootable CD and it just attempts to load the hard disk after. You can tell if this is happening if the CD light is not flickering but the hard disk light is. hard disk light looks like a cylinder on most laptops.
good luck!
1helpful
I am getting a blue scree error on my IBM Thinkpad R51 that says unmountable_Boot_Volume. It will not let me run on save mode...it brings me back to the blue scree error message. I have windows xp
Unmountable boot volume = The file system is damaged and cannot be mounted.
To fix that do the following:
1.Put the CD first in the boot order and boot from the XP install disk.
2.When the "Welcome to Setup" screen appears, press R to start the Recovery Console.
3.Select your partition - it should be C
4.When you are prompted, type the Administrator password. If the administrator password is blank, just press ENTER.
5.At the command prompt, type chkdsk /r , and then press ENTER.
6.At the command prompt, type exit , and then press ENTER to restart your computer.
This takes a bit longer, but the system should boot back into Windows.
2answers
It starts with the lenovo screen and then goes to the Windows XP screen but it goes back to the Lenovo screen. What can I do so I wont have to restore my system again?
ok, press f8 key as the system is booting up, this will put you in safe mode,
if the system boots okay goto command prompt mode and type chkdsk /r to repair any files etc ,
Try booting up again, if the problem is the same then it a startup file that need repairing so goto safe mode, command prompt type bootcfg etc and try repairting it that way, us e the help command to point you in the right direction.
Regards
GeWiz
I CNAT GET TO COMMAND PROMPT NEED TO GET INTO COMMAND PROMPT TO TRY TO BACKUP FILES ON BAD H.D.
Are you able to boot to Windows? What version of Windows?
If it's Windows 9x, go to Start > Run then type 'command' (without quotes)
If it's Windows NT/2000/XP, it's Start > Run then type 'cmd' (again, no quotes)
If it's Vista, type Command Prompt into the search box in the Start Menu.
If you can't boot and you just need a prompt, try booting your XP CD and when asked, select to repair using the Recovery Console.
http://support.microsoft.com/kb/314058
Hope this helps!
Dell Optiplex GX280 Bluescreen and Hardrive problem
Insert the Windows XP CD-ROM into the CD-ROM drive, and then restart the computer.
Click to select any options that are required to start the computer from the CD-ROM drive if you are prompted.
If you have a dual-boot or multiple-boot computer, select the installation that you must access from the Recovery Console.
The system should boot back into Windows.
If that doesn't work follow the above steps again but after you type the Administrator password ...
At the command prompt, type fixmbr and continue the next two steps.
THIS SOLUTION IS ONLY FOR A DAMAGED FILE SYSTEM.
Computers & Internet Logo
Top Command Computers & Internet Experts
NOEL
NOEL
ADMIN Canada
ADMIN Canada
Mehandi Husain ...
Are you a Command Computer and Internet Expert? Answer questions, earn points and help others
