Televison & Video Logo
Question about Seiki Televison & Video
My seiki tv automatically turns off after being on for around 30 seconds
Posted by Jess Stewart on
Pete D
  • 3 Answers
Disconnect the TV from the internet/network. Mine was shutting off before I could get to that menu, so I shut off my wifi/router first, then disabled the network connection on the TV; then put the wifi back on.
Posted on Dec 02, 2021
  • Gastonix Paquette
    Gastonix Paquette Dec 15, 2021
    Hi Pete Me too same problem with a seiki 39 inch 2016 tv thank you for the advice i can go not on netflix but my tv works fine someone know why its done? do you have a way to listen to new netflix with this tv thanks in advance
  • kelly foot
    kelly foot Feb 09, 2022
    my 43" seiki was doing same thing, shutting down and restarting. I hit the menu button then 0000 to get into service menu and did factory reset, set up wifi again and now its fine.
Jeffrey Goodsell
    Habit-Forming:
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
Mine started to do the same today Seiki SE43FGT
30sec to 1 minute then auto shutdown.
Funny I've seen 3 other posts from today Dec 1st with same problem
  • 5 more comments
  • Anonymous Dec 02, 2021
    me too
  • Pete D
    Pete D Dec 02, 2021
    mine just started this too...planned obsolescence?
    Model SE50FYT that I bought in June of 2016.
  • Adele Recoskie-Rickard
    Adele Recoskie-Rickard Dec 02, 2021
    I have 2 tvs that just started doing this. One is barely used.
  • Pete D
    Pete D Dec 02, 2021
  • Jeffrey Goodsell
    Jeffrey Goodsell Dec 03, 2021
    OMG , why dose this work, unpluged the network cable and now it's all OK !! ** Mind Blown **
  • Carol Gelder
    Carol Gelder Dec 03, 2021
    I did the same..obs I cant get netflix ect but tv ok...my wifi is with SSE
  • Jean-Marc Girard
    Jean-Marc Girard Dec 14, 2021
    Same problem with our SE42FYT, tried all your suggestions, not working for me, when I disconnect from the WIFI, the TV stays on, but as soon as I reconnect the WIFI the TV shuts down between 30 to 60 seconds, any suggestions?
Seiki SE42FYT turns off after logo appears across screen
Please disconnect all accessories. Then turn on your tv again. Please make sure that neither the power button on the tv or that on your remote is stuck because this could lead to the issues that you've mentioned. Otherwise, you'd need to factory reset your tv.
Thank you.
My 40 inch seiki tv turns on for 30 seconds then turns off
When it turns off is it like it's unplugged or does it show a standby light?
What is the code fot Seiki UHD TV SC-50US820N for remote Atlas URC1056BO4
hi if it not listed on booklet that came along with the controller
try using the automatic search best luck
1helpful
What is code for Seiki TV?
Search Results
    Remote Control Code for Seiki TV - TWC Community Forums
    forums.timewarnercable.com/.../Remote...Code...Seik...
    Time Warner CableJun 5, 2013 - Does anyone know the correct code to use for programming the remotecontrol with the Seiki TV? ... The one they have listed for Time Warner is a 4 digit code(0178) so it doesn't work. ... I did some research and it appears LG or Samsung codesmay work for Seiki sets.
    Seiki TV remote code - High Def Forum - Your High Definition ...
    www.highdefforum.com > ... > DISH Network Forum
    Jan 30, 2011 - 7 posts - ā€Ž6 authors
    I purchased a 32" Seiki TV but there is no listed remote codes for this brand. Does any one know of a code that will work? Thanks.
My remote control is stuck on Closed Caption. want to get rid of this
On your remote control above circle second from left is button CC
press it.
It will turn on and off Closed Caption
Just bought a vizio, the tv turns on real pixelated but fixes itself in 15 seoncds
If I have trouble with a brand new TV I always take it back and am sure to get another brand entirely. Personally I've had good luck with LG, SEIKI, and Samsung.
3helpful
2answers
Seiki TV is in burn mode It is flickering from red to blue to white to black etc
Hold down the physical power button the side of the television for 20 seconds. The television will automatically reboot into normal mode while you hold down the power button after that point.
Top Seiki Televison & Video Experts
ADMIN Andrew
ADMIN Andrew
rhodesworks
Are you a Seiki Televison and Video Expert? Answer questions, earn points and help others
