Question about Samsung Televison & Video
Have a LN40C630K1F Samsung TV that will start flashing/strobing and only fix its to turn off and back on. Is there a more permanent fix for this.
Posted by Terri McCracken on
  • EllaCharlebois
    EllaCharlebois Dec 02, 2021
    [ JOIN US ] I get paid more than $60 to $70 per hour for working online. I heard about this job 3 months ago and after joining this I have earned easily $10k from this without having online working skills . Simply give it a shot on the accompanying site…
    Here is I started.……......>> http://Www.NETCASH1.Com
Axel Gringmuth
  • 79 Answers
Do you mean turning off with the remote? For a full reset you need to pull the plug and leave it off for min 2 minutes
Posted on Dec 02, 2021
Snow on screen with no picture.loud noise on audio
42" Vizio TV flickering strobing easy way to repair VW42L ...
? 2:49
https://www.youtube.com/watch?v=Qba7_YHnXwM
Dec 2, 2013 - Uploaded by ozzysslayer
42" Vizio TV flickering strobing easy way to repair VW42L HDTV10A LCD TV ... EASY How to Fix Samsung LCD TV Flashing Flickering Screen!Missing: vp422hdtv10a ‎snow
Vizio Replacement Boards - ecoustics.com
www.ecoustics.com > ... > Plasma & LCD TV Forum
Apr 15, 2009 - I have a vizio p42hdtv10A that just went into a black screen. .... I have a Vizio VP422 HDTV10A that will not stay on or show a picture. I removed ... Vizio vp422 hdtv10a
Dec 20, 2011
May 13, 2011
More results from www.ecoustics.com
Is LN40C630K1F samsung tv compatible with MHL? If not how do i get my phone mirrored on my TV, is there a way?
The Samsung LN40C630K1F is not MHL compatible. The HDMI port on the TV doesn't understand the signal from the tablet directly. You need an MHL to HDMI adapter: http://www.amazon.com/Cable-Matters%C2%AE-Adapter-integrated-Charging/dp/B00ESM3Q7K/ref=pd_sim_107_2?ie=UTF8&refRID=1A2PE0271GRC99HNF1G9 , instead of an MHL to HDMI cable. Be sure to make sure that the adapter is compatible with your phone. (Not all adapters work with all makes/models.)
I hope this helps.
I have a Samsung ln46c630 which was purchased in May 2010. For the last few weeks it has started to have a strobing effect. Switching the source sometimes fixes the problem. It will run fine for a while...
Any luck? We bought our tv (same one) in March of last year. It is doing the exact same thing. Time Warner has already came out and switched out the cable box and cables. We have a tv tech coming soon (contracted out from Samsung, of course...) Problem persists...
35helpful
2answers
My Vizio VX42L is flashing like a strobe light.
Mine did the same thing. Remove the stand and back of the tv. Be careful with screen do not lay on hard surface and scratch. When you take the back off you will see a board on the left side and a board on the right side. They are labeled slave and master. Remove the ribbon cables and take board out. There are 2 capacitors on each board (about an inch long). These are probably all bad (ends bulged a little with black stuff on bulged end). Radio shack has them for less than $2.00 each. turn the board over and you can read the size of the capacitor. You need someone who can use solder wick and remove all four capacitors and solder in new ones. Notice how the capacitors are turned. Each one is labeled with a dash for negative. Make sure you bend new capacitor connectors the same and put back in the same way. Put the boards back in the tv and attach all ribbon cables. Put back and stand on. hook up your power and cable box and you are ready to watch tv with no more strobe. Me, my husband, and son did ours last week. I looked up the problem on the internet, husband removed stand & back, son with the steady hand did the soldering. Family project that went well for once.
1helpful
Screen starts to flash like a strobe light
It sounds like you may have some bad filter capacitors in the power supply. The "easy" fix could be to replace the power supply board. These capacitors can act up as they warm up.
1helpful
Open Questions:
Televison & Video Logo
Ekse
 Francisco Mauricio...
