Question about Sony Computers & Internet
Sony sl2000 cover latch problem - Sony Computers & Internet
  • EllaCharlebois
    EllaCharlebois Dec 02, 2021
    [ JOIN US ] I get paid more than $60 to $70 per hour for working online. I heard about this job 3 months ago and after joining this I have earned easily $10k from this without having online working skills . Simply give it a shot on the accompanying site…
    Here is I started.……......>> http://Www.NETCASH1.Com
Mehandi Husain Suleman
  • Sony Master
  • 1,654 Answers
Hi
find link for Sony sl2000 video
https://www.youtube.com/watch?v=vQZkzFbXCy8
Posted on Dec 02, 2021
Jet boat SL2000 bilge pump location how to access it
the tray that houses the cleanout plugs needs to be removed and pry'd up. thr pump is straight down from there.
How do i install fido sim card in my sony ericsson
To install a sim in to a Sony Ericsson Z710i:
  • Remove the battery cover by sliding the battery release latch down.
  • Slide the SIM cars into it's holder with the contacts facing down.
  • Insert the battery with the label side up and the connectors facing each other.
  • Slide the battery cover into place.
How do I change my projection lamp for my Sony Wega KDF 50E2000.
Hello.
You have to get lamp fully assembled for easy replacement. That mean lamp should be purchased already installed in black plastic housing.
If you stand behind of your TV set on the left hand side (actual side) of your TV you will locate lamp door cover with latch on the top of it. Just push the latch down and remove cover. Deeper inside you will locate black plastic lamp door with handle that you have to rotate 1/8 of the turn counter-clockwise to open it up ( like a submarine style thing). Pull it out and next thing that you will discover - lamp assembly itself. Put your index finger inside of the ring-looking latch, pull it up and out. You have lamp removed now. Extremely carefully install new lamp in same order making sure that new lamp is ALL WAY IN (there is safety switch that sense if lamp is not properly in) and install the door making sure it is ALL WAY IN and LOCKED (there is another safety switch that sense it). If any of the switches will not sense proper installation TV WILL NOT turn on.
You can turn TV on to check if it is working. Last thing to do - reinstall lamp door cover.
Russ.
The opening for the batteries is broken.
The 4 latches that the battery door locks onto is broke, you will need a different back cover and front cover.
Sony DSC-T70 CyberShot memory/battery cover broken
Assuming that your Sony DSC-t70 has black color cabinet then you need battery Compartment with following part number...
X-2186-609-1 ASSY, BTH (B) (BLACK)
IMPORTANT (If camera has different color cabinet, let me know to provide you appropriate part number)
Above said part is available in Part Store on $33.42
Dvd door wont open
Some part of the ejection system is malfunctioning possibly due to bent or broken latching components. Take unit to pro tech
2answers
Door does not stay closed
The latch that holds the door has snapped. time to take it apart. The spring may have come off or you could need a new unit.
6helpful
4answers
Sony Cyber-Shot Battery Compartment Door Broken
I'm having the same problem with my DSC-W1 camera. I dropped my camera and the battery door latches broke.
I found a replacement door on Ebay for $9.95
I followed the instructions in the description and easily removed the broken door from my camera. Now i'm just waiting on the new door to arrive so I could slide the new door in.
I hope this was helpful.
Here's the seller I bought the door from. Hopefully the seller has more doors. =) :
http://cgi.ebay.com/Sony-DSC-W1-battery-door-silver-battery-cover-lid_W0QQitemZ110250995036QQihZ001QQcategoryZ107892QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
In addtion, I found the last two posts on this forum very helpful:
http://www.digitalcamera-hq.com/digital-cameras/sony-cybershot-dscw1_question.html?qid=2382
Good Luck! =)
Computers & Internet Logo
Top Sony Computers & Internet Experts
Ekse
Mehandi Husain ...
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
