Question about La Cimbali Coffee Makers & Espresso Machines
La Cimbali M34 Espresso. One side of buttons are not lit up or working I can also see an error of E 283.
The buttons are touch screen not actual buttons.
Posted by Rebecca Walker on
ADMIN Canada
    Top Expert:
  • La Cimbali Master
  • 42,942 Answers
Question edited for clarity.
Question moved from Cellphones to La Cimbali. If you put 'make model (what it is)' at the beginning, you are more likely to be offered the correct Category.
It is a Professional Espresso Maker Rebecca. It needs professional service. Contact their support direct. The first thing to try is disconnecting from power for 5 minutes.
https://pdf.archiexpo.com/pdf/la-cimbali/m34-selectron/11548-253308.html
Posted on Dec 13, 2021
I need to see a wiring diagram for a la cimbali espresso machine m2
These super automatics really require a service tech. Please contact your vendor or cimbali.com for current contacts
ukeboy57
My la cimbali jnr wont fill up when i press the button to fill tank it makes the noise but no water is going in
1. Check water line for pressure and flow.
2. Check water filter or water softener for pressure and flow.
3. call for service; Clogged water pump, pipe, orifice, tank.
ukeboy57
3helpful
2answers
La Cimbali Espresso Machine: How do you calibrate the dosing for a Cimbali M29 ...
Press and hold any Group stop button until beeping, then all the button will copy what you press. Hit any stop button to leave program.
How do you calibrate the dosing of the La Cimbali M29 Select?
should be the same method unless the stop button needs replacement. The stop button is one of the most often used (abused) buttons and frequently needs replacement.
ukeboy57
I have a La Cimbali Domus classic servicing required
check cimbali.com for current contacts.
youtube; ukeboy57
Can you turn off one of the left or right sides on a La Cimbali m29 Espresso machine?
1-Cover the buttons on offending side (paper and 1 min to do)
2-Reprogram one side to give it a short dose. (5 mins to do)
3-remove power to group valve (screwdriver and 20 mins to do)
Note if you do remove the power, please leave a note for the crew as they will probably call a technician in to 'repair' it again.
5helpful
3answers
La cimbali m28 selectron manual could anyone tell me where to buy or down load one
This is for you....I hope this M29 will do what you need...I called he Cimbali 1-800 number and this is all they had...I tried...been working on this one for about an hour...found one in Russian....Italian...Spanish....but when I translated them and tried to paste them they came in both languages and intermingled somehow....wierd....but here you go ....I hope this helps...good luck and thanks for rating my effort....The Fang
P.S. any probs...call 1-800-724-6225 and speak to Trish. Thats 1-800-Cimbali. Take Care
2helpful
I have La Cimbali Dosatron M20, working perfectly, i have only 1 problem. Dosing of water for cups, i want to change but i dont know how. i would apreciate if you can help me. Regards, Sulejman Sulejmani
Hold down the stop button for 8-10 seconds or until you hear the faint beeping sound, press button to program when you get the correct level press stop button. On some models you have to hold the button until you get the correct level then release. When you are done programming press stop button a second time to exit program mode.
Cimbali M29 Select
Remove the 3 screws on the side of the bell they might be bolts or allen wrench screws. That will give you easier access to the screen and screw(make sure you have extra screen and screws).
Coffee Makers & Espresso Machines Logo
Top La Cimbali Coffee Makers & Espresso Machines Experts
Pierre Laplante
Kolbrun...
Ross Keen
Are you a La Cimbali Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
