Question about Kenwood Car Audio & Video
There is no red nor white rca input on my kenwood KVT-512
So I hooked my kenwood KVT-512 up today it works I bought everything subs and a box and the wiring harness and more it came time to run the RCA cables from the amp to the deck I went to plug the RCA cables and there's no red or white or anything just a yellow cable and a black one so I plugged them into that because that's the only thing on the back of the kenwood KVT-512 is the yellow and black cords so can someone please let me no sense there's no red or white inputs to plug into like a normal cd player do we plug the RCA cable into the yellow and black and electrical tape them so they don't fall out please help me
Posted by Tony Engle on
Michael RATHOBOTHA
Hi.. Same problem.. I went bought something called high and low converter, hooked it @the back of my OEM harman radio... Works properly
There is no red nor white rca input on my kenwood  - screenshot_20211203_152640_com.opera.browser-town2aqw4nyk3bhnghm3rasp-6-0.jpg
Posted on Dec 03, 2021
JVC SP-PWA-235 has one input and I'm hooking it up to a Kenwood Stereo System. The receiver has 3 inputs for the sub-woofer, red/white & black. I just need to know if I use the red or the white...
The 3 RCA type connectors (red, white,black) are all pre-amp outputs, not inputs. (Cut the girl some slack) the black is for the subwoofer. The red and white are pre-amp outputs for either up converting from a 5.1 to a 7.1 system, or for running a X.2 (2 subwoofers L &R). If you are running 2 subs, be sure on one of them to reverse the polarity.
2answers
Ive got a kenwood kvt-512 n im tryin to hook an amp n subs up but dnt know where to plug my RCA jacks from the amp 2 the radio!
Your unit should have 2 plugs in the back...one for the audio and power wires to connect to your factory connections and the other plug is just RCA connections for your video, subs and front speakers. If you have a 4 channel amp and a amp for your subs, you will have to split the 4 channel amp down to 2 and run them to your front RCA connections. Subs will connect to the sub connections. If yours are not listed then you may have to track down a wiring diagram. Hope this helps.
When I hooked my subs up to my KVT-512, the subs only turn on when the Radio is on, but whenever I put in a CD or plug my iPod in, the subs do not work. Can anyone explain why this is happening? Thanks!
you are so close your gonna hate youreself a lttle your connected to the blue power antenna wire connect it to the blue white remote turn on and your all done
I need the site for kenwood kvt-512 update
try this I use this for getting user manual or leave them a question Good Luck!!!!
Techman
http://www.kenwood.ca/Support
1helpful
Where is the rca input in the back of the deck to run subs. do i need additional harness
This unit does not have a dedicated subwoofer output.
CLICK HERE
for the manual in PDF format
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
1helpful
Kenwood KVT-512 iphone compatibility
Just ignore the airplane mode prompt and if your wiring is correct everything should work.
With my BMW I had to connect both the solid blue (pwr ant) wire and the blue with white stripe (p conn) to the solid blue wire from the factory harness.
It isn't obvious that either of these are needed as the KVT-512 has it's own power supply but the way most factory power amps are installed the power from the KVT-512 is not used and the car manufacturers power amp needs to be turned on.
If you are listening to the radio the pwr ant wire will turn on the power amp, this didn't seem obvious because the BMW doesn't have a power antenna. And when you are using the DVD player or the iPod connection you need the P Conn wire to turn on the car power amp as the ant pwr is disabled because you are no longer using the radio and Kenwood assumes you will not need the antenna so no power to this lead.
Solder all three wires together and you should have sound all the time.
2helpful
Cant get bass, fuse is fine
You don't say if you've configured the Receiver to know you have a subwoofer (under Multicontrol - SUBW YES). Unless it knows about the Sub it won't send anything out that single "preout". You can get an RCA splitter to run that single output to both inputs in the Sub.
Just as an experiment, temporarily run one a pair of cables from the REC OUT to the Sub's inputs and tune an FM station to prove the Sub amplifier is alive. If it's still silent, it's dead. If there is sound (muffled) you need to go back to the Receiver to figure out why the Sub Preout is signal-starved.
6helpful
12helpful
Kenwood KVT-512 subwoofer
put it in standby mode first.. then switch the rear av-out to sub.. then you can turn the sub on/off
1helpful
Kenwood kvt 815
I NEED HELP TO UNLOCK A KENWOOD KVT 815 PLEASE HELP THANKS CHARLES
Car Audio & Video Logo
Top Kenwood Car Audio & Video Experts
 Francisco Mauricio...
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
