This past weekend, we noticed that our Whirlpool dishwasher Model #: WDT730PAHZ0 is no longer spraying water during wash cycles. It will draw water into the compartment, and drain out when the cycle is done -- but in between, there is no physical spraying of water through the sprayer arms. The unit is completely silent during those times when it would normally be spraying. We have tried different cycles; but the behavior is the same on every one we've tried. The unit is a little over two years old. Are there any suggestions on what we should be attempting in terms of trouble-shooting?
The motor is shot. A dishwasher can fill and drain water without the use of the main wash pump. Water pressure is what fills a dishwasher. A second smaller pump is what drains the water. The main water pump (wash motor) is responsible for for spraying water throughout the dishwasher’s chamber. When this goes out, it will be too costly to repair.
Check water pump and make sure there is no bloks in the pipes try using a good dishwasher cleaner and if its got the turn bit on base inside open it and make sure filters are clean blessings
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
k
