Question about The Computers & Internet
What does it mean when direk-tek laptop is not turning on and the red light keeps blinking
Suppose to be I`m going to reformat my direk-tek laptop and when I insert the usb drive using for format, the laptop suddenly turns of but the usb port is functioning. And when i plug in the charger, the red light keeps blinking. I cant turn it on
Posted by Masayuki Danieles on
  • Anonymous Dec 02, 2021
    you posted with no PC model told,just a series name ?
    and no OS told.
    most laptops fail 99% under 5 to 7 year sold for bad batteries, (hint the do not last long)
    first unplug the exernal HDD, USB? so it does not overload the PC, the hDd uses 1 amp of power 12 watts.
    here is what you do
    remove the huge battery first, they shot and when they do (and not catch fire) they overload the main power rails in the pC, that means the power pack too is overloaded.
    so we remove big BAT first, and test the PC only on AC power, and then see if the old HDD external is working.
    is that external 2.5" or 3.5" hdd? if 3.5" it must have ITS OWN POWER pack or USB will be overload.
    power is king in electronics, it must be good first. not 2nd or 3rd it is first .
    welcome to bad big battery, all fails old.
    Direkt-tekhttp://direkt-tek.com/support/#lapsuppor...
    what model is it, I can not guess models.
    DTLAPC14-1-PK <<< random model. on sticker lable bottom of laptop.
    the thin models, cracker thin I call them have the huge battery inside ultra thin but huge.
    and must be removed, to test any lamptop made, this fails first. 2nd is hdd, bad.
    and a coin cell too can be bad.
    or remove the hdd, external, unplug the huge battery
    and BIOS (hotkey) page 1 tells you the model PC you have.
    DTLA nnnnnnn
    it may look like this.
    https://www.youtube.com/watch?v=ml5pcw85...
    remove it and even run on AC pack for ever, or buy a new one to get back portability. (if needed)
  • EllaCharlebois
    EllaCharlebois Dec 02, 2021
    [ JOIN US ] I get paid more than $60 to $70 per hour for working online. I heard about this job 3 months ago and after joining this I have earned easily $10k from this without having online working skills . Simply give it a shot on the accompanying site…
    Here is I started.……......>> http://Www.NETCASH1.Com
Steven De Weese
  • 3 Answers
You could try removing the motherboard battery, then hold your power button for 15 sec replace the battery and see if that helps.
Posted on Dec 02, 2021
Mehandi Husain Suleman
  • The Master
  • 1,654 Answers
Hi
I removed the battery n pressed the power button for 1min and then plugged it back on but when I press the power button, an orange light flashes 5 times and then stops... but still no display
Posted on Dec 01, 2021
TV SHUT OFF, HASPOWER, RED BLINKING LIGHT, WON'T TURN BACK ON, WHATS THE PROBLEM ?
If the red light is blinking, then it either does not have a good power connection or its in a diagnostic mode. The red light should be solid not blinking.
If you need further help, reach me via phone at https://www.6ya.com/expert/brandon_bf4b4a06876c89a0
1helpful
Tv turns on for less than 30 seconds and turns off and red light is blinking
Hi John,
TV going off in thirty seconds and red light blinking means there is something wrong inside your Tv and it should not be working in this condition and hence is the "going off" happening. The automatic protection inside is switching your tv off. Please consult some local TV tech. There is nothing you can do about it yourself.
Good Luck.
1helpful
2answers
My ps3 won't turn on and red light keeps blinking,
Read this:
http://www.prlog.org/10506996-ps3-red-flashing-light-causes-and-solution-revive-your-ps3-by-fixing-red-lights-blinking-yourself.html
Hi I have recently purchased the belkin wireless surf router and I am not sure if it is working correctly or not, as the light on the front of the router is currently blinking red.. and red doesnt really...
hi
IS THE LIGHT IS BLINK RED MEANS YOU DONT HAVE A PHYSICAL CONNECTIVITY.
PLEASE CHECK YOUR MANUAL AND YOUR CABLE CONECTIONS.
STEP1
TURN OFF ROTER AND MODEM
STEP2
CONNECT MODEM CABLE TO WAP PORT ON ROUTER AND LAN CABLE TO PC OR LAPTOP
STEP3
NOW TURN ON FIRST MODEM AND AFTER A 5 MINUTS TURN ON ROUTER, YOU WILL SEE LIGHT IS TURNING ORANGE AND AFTER THAT GREEN
READY NOW JUST ENJOY YOUR ROUTER.
ADVISE:
DONT INSTALL THE CD SOFTWARE DO ALL MANUALLY.
FOR GO IN TO YOUR ROUTER SETTINGS PLEASE LOG IN IN THE INTERFACE USING 192.168.2.1 OR JUST WRITE HTTP:// ROUTER
ANY QUESTIONS PLEASE TX ME .
TECHBELKIN
The blue light keeps blinking and error e04 comes up
I have a DPAC 1200068 air conditioner and the red light keeps blinking and I need to know how to shut it off so it flashes when it is suppose to and go off when it is suppose to.
1helpful
We have a problem similar to timmiby
Hi, replace the lamp, be sure to follow directions carefully as that set is known for door switch issues, gl, video-tek
Tv turns on but no picture just a red blinking light stays on
Red light blinking means there's a problem in the TV....
What kind of tv is it?
2helpful
3answers
Norelco Advantage red light meaning and source of manual
the steady red light showing when in charger shows that
it is charging. the blinking red light when taken out of
charger or turned on and off means it is not fully charged.
leave it in charger till red light turns green.
2answers
Blinking red light
What laptop brand and model is it? And where is the LED that blinks? Important details! Some laptops have a power light that blinks red while battery charges, then it turns steady green when battery is full. Some laptops have a red LED that lights whenever there is hard drive, CDrom, or floppy activity (read/write). This all depends on your laptop brand/model and where the LED is (side, near floppy/CD, top near screen, or on battery itself... so provide more details for me, please!
Computers & Internet Logo
Top The Computers & Internet Experts
Mohamed Alazhary
Mohamed Alazhary
A Kisling
A Kisling
EKASYS IT SERVICES
EKASYS IT SERVICES
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
