My Funai TV model LF320FX4F reads 'resolution mismatch on HDMI 1'. I use a firestick and I do not have cable. It's been down 3 days. Help please.
I've tried every solution Google offered, ioth no results.
Posted by Sheila Canler on
  • Larry Ng
    Larry Ng Nov 30, 2021
    it did not lie to you Sheila. "FIReSTICK LITE" ??????
    page 14 in the TV manual states 60hz refresh max and (A 2013 MFG TV)
    The unit accepts 480i, 480p, 720p, 1080i and 1080p video signals then contradicts stating max is
    1,360 x 768
    SAD THAT.
    does firestick WORK ON ALL TV , ANSWER IS NO. NOT ALL.
    No, Firestick does not work on any TV – it must have an HDMI port! If you have an older, lower resolution TV, your Firestick should automatically down-convert to the best available resolution. On rare occasion, some old, 720p TVs cause an “invalid format” error and cannot be used with Firestick.
    READ THE SECTION , MANUALLY CHANGE HERE.
    https://goodhomeautomation.com/does-fire...
    try setting the stick to one of these supported resolutions.
  • Larry Ng
    that post is from your TV manual, free, to read.
Larry
  • Televison & ... Master
  • 3,898 Answers
This should be an easy fix, on your firestick remote select the home button, then settings then display and set it to automatic this way the firestick will adjust to your TV res.
Posted on Nov 30, 2021
How to reset my funai TV resolution mismatch
On your remote control, press MENU.
Highlight Settings with the down arrow button, then push OK.
Press OK after highlighting Television with the down arrow button.
Select TV resolution, then click OK.
Select HD 720p, HD 1080i, or HD 1080p using the arrow buttons.
Click OK.
How do you go to live TV from Firestick?
I switch from firestick to live TV by using the television's remote control. Its located under the "input" button. Select between tv, HDMI 1 though 4, (my firestick is on HDMI-3), video-1, and DVD.
Is there update firmware for LF320FX4F Made In Oct. 2013
According to the product support page, Funai has not released any new firmware for the LF320FX4F. Go to http://funaiamerica.com/product/product.php?id=880 and click on the Downloads tab. You can also check for updates from the Support Downloads page, http://funaiamerica.com/support/download.php , by entering the TV model number.
I hope this helps.
I cannot find a 3 digit code that will work to program my Star Wars Lightsaber remote to this tv! Please help!
Manual Star Wars Luke Skywalker Lightsaber Universal Remote Control 4.99
you will not find a free manual,they are all for sale,get 1 and sell copies.
matter of fact,dont use it and sell it for a couple hundred
1helpful
WHAT TO DO IF MY FUNAI LF320FX4F FLAT SCREEN ...WILL NO LONGER COME ON, AND WHERE TO FIND THE FUSES, OR ORDER A REPLACEMENT POWER SUPPLY?
Try to powercycle the tv by unplugging then pressing the power button and hold for about 1 minute. Once you have done that replug and see if it works. If not, most likely is a mainboard issue. There is a kit available for repair here that you can use that includes all of the parts so you don't have to waste time trying each one at a time. http://digipartsdirect.com/listKits.php?brand=Funai&SId=3
Funai lf320fx4f
it should look like
3a8058d6-5d05-4fc8-aa1e-b624777960e9.jpg on computer
Not sure on the cable depends on tv connection for hdmi and hdmi connector on P.C take a photo of each and take with you to store to avoid mistakes
this could be most likely cable
http://www.officeworks.com.au/shop/officeworks/comsol-male-male-hdmi-ultra-thin-av-cable-1-5-metres-cohdmi15st.
However mini connectors are used sometimes so matching the cable could mean looking up computer specifications on type of hdmi used and television specifications on type of hdmi interface used.
I am attempting to connect a PC and/or a Playstation 3 via an HDMI cable and my Samsung Plasma Model HP-5033 will not read the signal between the PC and television. It reads a "No Signal Detected" message...
Adjust the computer resolution to 800-600 and set the lowest bit rate, ie not 32bit. 24bit or 16bit will be fine.
To do this right click on the screen and choose properties, click on settings and you will see the slider bar the resolution and the drop down menu for the bit rate.
The reason you have to do this is because even though its a tv it works on a lower resolution than a computer monitor and is unable to show higher res.
Open Questions:
Televison & Video Logo
Top Televison & Video Experts
Ekse
