Question about Kyocera FS-1035MFP
Fs 1035mfp reset maintenance kit message
About one month ago, I recently replaced a new toner and maintenance kit. How can I reset the 'Replace MK' message on my Kyocera FS 1035 MFP? The message just started showing up on the screen today. I tried logging in to System settings to restart the machine, turned unit Off/On and even reseated the drum/developer. Nothing seems to work. ***UPDATE*** I have been able to reset the counter using the answer below: 'Resetting for replaced MK kyocera fs 1135'. 1. typing in the codes 1087 1087 251 2. then going to menu item to reset the maintenance counter
Posted by David Wong on
Mehandi Husain Suleman
  • Kyocera Master
  • 1,654 Answers
Hi
find link for solution
https://www.youtube.com/watch?v=Dco3csuDDkQ
Posted on Dec 02, 2021
Install MK Kit Kyocera FS-9130 How to reset MK Kit Counter
you can reset the counter but on the falcon engines if you go past the maint. cycle they will eventually fall down and print solid black copies.
2answers
Message on screen says "Waste Toner Box Full"
Typically you will need to replace the waste toner box. There is usually a difficult to access part of the bottle that is used by an optic sensor to tell when the box is full. Plus toner is very fine and you do not want it getting into the air. Toner will pass through the filter of most vacuums and go back into the air.
press numeric keys 1087 1087 , then 251
Checking/clearing the maintenance count Description Displays, clears and changes the maintenance count. Purpose To check the maintenance count. Also to clear the count during maintenance service (replacing the maintenance kit). Method 1. Press the start key. The maintenance count is displayed. Setting 1. Select [M.CNT A] using the cursor up/down keys. 2. Change the setting using the cursor left/right keys or numeric keys. 3. Press the start key. The count is set. Clearing 1. Select [CLEAR] using the cursor up/down keys. 2. Press the start key. The count is cleared. Completion Press the stop key. The screen for selecting a maintenance item No. is displayed. Item No. Description Description Setting range Initial setting Maintenance count 0 to 9999999 0
1helpful
C3100 toner waste
replace the waste toner bottle. your new toner should come with spares
4helpful
3answers
Kyocera FS-4000DN is showing install MK; Can the problem be fix without buying a Maintence Kit for $532?
> without buying a Maintenance Kit ?
Either you buy the kit, or you sell the printer "as is" on eBay, after buying a new printer.
2helpful
KYOCERA fs-1920 Has the message instal MK coming up? Dopes this mean order a maintenance kit?
It means the page count has triggered this message.
You _should_ get a maintenance kit.
But if you simply can't take the time/money, you'll find a new menu item in the menus after service. the new item is 'maintenance', get to there and press enter. (May need to press enter twice), the menu item, flashing light, and install MK message will all disappear.
1helpful
We have a Kyocera FS3830N - message install MK -
MK is the maintenance kit. You can check the Kyocera site to find out where to get a new kit and how much they are:
http://usa.kyoceramita.com/americas/jsp/Kyocera/products_printers_details.jsp?pid=12331
Most of the time the message is just displayed because the machine has reached a certain number of pages, but it should still let you use it normally.
2helpful
Install MK? What does this mean?
Its because you've gone past a certain number of pages printed.
Its asking you to install a new Media Kit
To reset the message -
1 Press the MENU key.
2 Press the or key repeatedly until Life Counters > appears.
3 Press the > key.
4 Press the or key repeatedly until >New Toner Installed. appears
5 Press the ENTER key. A question mark (?) appears.
6 Press the ENTER key.
The toner counter is reset. The message display returns to Ready.
47helpful
2answers
Message stating install MK
You have done more than 300,000 pages. I wouldnt waste your money on a Maint Kit, just stretch it out by doing the following.
Press Menu/Ok (Main menu)
Go into [>>Service]
Then press the right arrow.
Then find [>> Maintenance]
Press the ok key, then it will show [>> Maintenance?]
Press the ok key twice, and it will reset all the counts on your consumable components (Drum, Developer, Transfer Roller, ETC)
2helpful
New maintenance kit
Hi Did you run up the developer unit? Menu button down to Other then to Service and press enter on developer and switch off and turn on will run for a while. In the service menu after you run up the dev unit you may have a option in there to press enter on the MK Symbol.
Cheers
Kyocera FS-1035MFP Logo
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Kyocera HP Expert
George Mclaughlin
Ekse
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
