Question about Samsung Televison & Video
Do I need a new T-Con board for my Samsung UN55JS700DFXZA ?
I bought a used Samsung UN55JS700DFXZA recently and when turned on it seems to work fine but makes an abnormal buzzing noise. I removed the back plastic cover and did some rudimentary testing and found that when the flat ribbon cable from the main board to the T-Con board (what I would consider the 'input' to the T-Con board) is disconnected the buzzing stops. But, if the input cable is connected and either or both of the 'output' ZIF cables (T-Con board to the screen) are disconnected it still buzzes.
  • BernicRobinson
    BernicRobinson Nov 29, 2021
    [ JOIN US ] I get paid more than $60 to $70 per hour for working online. I heard about this job 3 months ago and after joining this I have earned easily $10k from this without having online working skills . Simply give it a shot on the accompanying site…
    Here is I started.……......>> http://Www.NETCASH1.Com
Larry
  • Samsung Master
  • 3,898 Answers
Can you tell where the buzz is coming from? I think what may be happening is one of the PMW transformers on the power board is making the noise, when you unhook the LVDS cable (main to timing board) the load put on the power supply drops because the timing board uses a fair amount of power and the transformer(s) quit buzzing. It's very possible I'm wrong on this but I've seen this happen before. Another thing is you said the set works ok, if there was an issue with the tcon the set wouldn't work. Try to isolate the sound, if it's coming from the power board you could order a new one or just use it the way it is as it shouldn't hurt anything.
Posted on Dec 05, 2021
  • Anonymous Dec 05, 2021
    It's very hard to determine where the buzzing is coming from, it almost seems like some or all of the back light LEDs are buzzing, the noise is really spread out across the entire TV. Last week I found a T-Con board on ebay and swapped it out, no luck, still buzzes. The buzzing itself is at 120Hz, if that tells you anything.
How to perform EEPROM reset on BN94-07345C Main board for Samsung LED TV UN55H7150AF?
The EEPROM on the main board can't be reset, ether to replace a new ROM, or change the main board.
How to fix an intermittent white screen on a Samsung television?
Ask them to replace the t-con board. It could be a defect one.Good Luck.
Serge.
Polaroid 3211-TLXB solarized / negative image
Just replace the T-Con board and you dont need any soldering at all. JUst be careful for the flex connector.
2answers
Samsung ln46a550p3f has distorted color
what do you mean by distorted?
are colors wrong? or are colors washed out?
Samsung LCD model #LN32A330JIDXZA has a very bright color, can hardly see the picture
My problem began the same way, then the tv turned off everytime I tried to turn it on. First I opened the tv, made a list of all the electrolithyc caps values and temps in the power board and gone to the store and bought all except the bigger one (like USD 8) changed all the caps and then the tv didnt turn off again but image was all white.
Then searching in youtube found about the t-con board issues but the entire card was too expensive to dump so searched how to repair the t-con and found I can change the main chip so bought 2 in ebay from china took like one month but was just USD 8, so carefully cut all the old chip legs, retired the chip, used a soldering iron to retire the old legs, cleaned, put bits of new solder in the tracks, placed the new chip and began to paste leg by leg, tested continuity and checked for solder bridges between legs, assembled, turned on the tv and half screen has strips bot the left side was ok so rechecked flex cables between t-con and lcd and found bent tracks, carefully repositiones, assembled and now my mom has a brand new samsung 32in LCD to watch CSI and stuff... Sooo F_ck u Samsung LOL
Hope you can repair yours, every problem is a world so may not work for you but for USD 8 in chips, patience and some pulse soldering i think it worth the try.
1helpful
Recently bought samsung multi split 3 rm air conditioner. 2 of the room air con working fine but the 3rd room fan coil seems to be blowing only cool air not like the other 'aircon' feel coolness. Got the...
doesnt sound like a gas problem. theres a vavle they opens and closes inside the unit that might be playing up either the vavle or the indoor pc board. did it ever cool ? might also be the vavle on the outside unit were not open with the alan keys so theres no gas going to them .
2answers
I bought this on clearance. I hooked it up and
Samsung LN40A550 LCD TV
This is probably the LCD Controller (T-CON) board connections. This is a small board with 2 flat cables connected to it which run to the LCD screen. The connections with the flat ribbons needs to be reseated. The heat makes the connections misaligned. This board is usually covered by a metal shield.
When you reseat the connections, run the set for 15 minutes to see if it works before replacing the back cover. You may have to reseat it again.
Remember, handle electronics boards by the edges, no static electricity, and do not touch the connection contacts.
At worst you would need a new board. (Shopjimmy.com has it for ~$90.00usd)
Open Questions:
Televison & Video Logo
Ekse
 Francisco Mauricio...
