I assume this is an active sub. The amplifier has most likely failed. You have proved the signal source is not the problem, well almost if you can sucessfully connect the aiwa sub to another amp then we will know for sure. Usually amplifiers fail with an output device short circuit. The hum you here is the power supply direct on the speaker, I would not leave it on for long or speaker damage may ensue.
