Question about Canon Cameras
Canon Powershot a1100 will only switch on and stay on if I press the battery cover. No obvious damage to connectors.
Canon Powershot G5
Replace the Cover as it could damage the lenses. Go to Cannon Custer Support for instruction on how to assemeble or disassemble parts.
I dropped my cannon powershot a1100 it'll play back the pictures on the memory card but the lens won't come out to take any pictures. and when i push the on/off button it won't work. how can i fix it?
It sounds like you dropped it on the lense, and the little motor inside that moves it broke. If you still have a warrenty on the camera, exchange it at the place you got it or send it to the manufacturer.
1helpful
My cannon powershot A1100-IS battery compartment cover was broken. can this be fixed?
It can almost certainly be fixed, but you will need to send it to Canon service center for repair, a phone number to get this information is listed in the user guide. This will be fairly expensive so make the decision based on the age of the Camera and what it is worth to you.
How do you restart the canon A1100
http://www.freeservicemanual.co.cc/canon-powershot-a1100-user-manual/
canonpowershota1100.com/wp.../canon-powershot-a1100is-manual.pdf
This info is all in the user manual, so I have found one for you for later reference. Please simply download from the link above....
in any event the best way to restart is to Power OFF & then ON again, this will reset all settings and restart the software again.
I have a cannon powershot a1100 IS and it keeps telling me that the card is locked..what should i do?
Look at your memory card. SD and SDHC cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Powershot A1100 is error lens restart camera
try these:-
  • connect it to pc and on it
  • vaccum the barrel of lens
  • changing mem. card and batt. for 2min.
  • shake it.
  • on and off in different positions
I have just got a cannon a1100 is camera and i was told when ordering it that it was rechargable can u tell me how when it came with no charger and normal batteries
i was told when ordering it that it was rechargeable; - well it will take rechargeable batteries, BUT i suspect that was not what you asked the salesman. I think they have been a bit naughty with you...
That camera is supplied with ordinary batteries see the specification here http://www.canon.co.uk/For_Home/Product_Finder/Cameras/Digital_Camera/PowerShot/PowerShot_A1100_IS/index.asp?specs=1 scroll down to power source section,. BUT you will see that camera will also take NiMH Batteries(NB4-300) which are rechargeable, you can get these batteries and a charger very cheaply online - so yes it will take rechargeable batteries but does not come supplied - That can be useful, because if you run out of charge the camera is useless, with these type of batteries at least you can keep a spare set, and if necessary goto any shop and buy AA size batteries very easily, I know I could have used that facility on one of my cameras which takes a special battery and even with a charged spare - we ran out of power ....
Cameras Logo
Top Canon Cameras Experts
old marine
old marine
Ekse
Steven Wander
Steven Wander
Are you a Canon Camera Expert? Answer questions, earn points and help others
