Question about Onkyo Audio Players & Recorders
I want to connect my kenwood ge-34 graphic eq to my onkyo ht-r530 av reciever
Posted by Tony Tackett on
HOW TO HOOK UP A KENWOOD GE-34 GRAPHIC EQ. THE EQ HAS LINE IN AND OUT RCA JACKS AND TAPE PLAY AND RECORD RCA JACKS.MY RECEIVER IS ONKYO HT-R530. IT HAS TAPE IN AND OUT RCA JACKS
The EQ is made to go between two devices such as a preamplifier then to the EQ then to your receiver or TV to EQ then to your receiver, depending on what you are trying to do. This is how you hook it up. TV line out goes to EQ line in. EQ line out goes to receiver line in. The receiver is then selected to use line in by a push button on your receiver or by other means that says line in to select that as your source from the front receiver panel. The red rca line cable is for the right side and the white is your left side of the audio. your receiver now can hook to the speakers and you have control of the volume up and down from your receiver. Now if you are going to go from your receiver to a high powered amplifier then the line out on your receiver would go to the line in on the EQ and the line out on the EQ would go to the amplifier line in. The amplifier would have to be able to control the volume up and down as line in and line out volumes are fixed. Record output jack is for recording where the jack goes to a recording device line input. The play is the recorder line out that plugs into that jack. Ignore those two jacks for your purpose.
MANUAL GUIDE OWNER ONKYO RECEIVER AV HT-R530
Hi Javier, you can located the owners manual at the following link, http://www.onkyousa.com/Downloads/manuals.php?source=globalnav. Note that your unit is part of the HTIB HT-S780, Thanks, JT
Hola compre un receptor ONKYO A.V. HT-R530 Y NO SE SU FUNCIONAMIENTO PORQUE TIENE MUCHAS OPCIONES Y QUIERO SABER COMO FUNICONAN.
Hola Javier, puedes llamarnos al 800-229-1687 tenemos technicos que hablan espanol que le pueden ayudar, Gracias, JT
Turntable with onkyo HT-R530
You cannot plug in a turn table to this receiver because it does not have a pre-built pre-amp. So unless your turn table comes with a pre-built pre-amp you cannot use it with this receiver.
Onkyo ht-r530 subwoofer stopped working
Turn the out put leval down on your sub, End the reciever, I was turn up to high,End that will cause it to cut out.
1helpful
Wire Kenwood GE 7030 equilizer to onkyo tx sr504 receiver
The manuals explain it.
http://www.retrevo.com/support/Kenwood-GE-7030-manual/id/479dj189/t/2/
http://www.retrevo.com/support/Onkyo-TX-SR504-Receivers-manual/id/365ag215/t/2/
For all practical purposes an EQ or any analog audio processor connects exactly like a Tape Deck - into any RCA pairing that has both an OUT and an IN and can be selected to be in or out of the audio path.
However, on this and just about any modern digital-capable AV Receiver, activation of any external loop that would connect a processor or tape deck would automatically DISable any digital audio sources. The effects of the processor, therefore, can only be used with analog stereo sources. It WILL affect the sound going to all speakers if you use the various Digital Sound Porcessing modes as the extra channels are derived from the stereo channels anyway.
Onkyo ht-r530 Receiver troubleshooting
the 7.1 sound not all the movies has that feature and u need to emulate it, doit in the dolby digital ex and the speakers must sound.
try the volume for the SBL or SBL maybe are to low.
decrease the volume for all the speaker less the SBL, SBR and check it out.
Good Luck
1helpful
2answers
CONNECTING
you can do it passive. no idea with your ampli, but if it does have a bridge then you can hook your eq there, series. if it doesn't have then via tape monitor 2 of your kenwood.
onkyo recvr tape 2 record to - kenwood eq in
onyo recvr tape 2 playback - kenwood eq out
that's all. if you want your eq to be active, then switch your reciever to tape2, all selected input in your reciever will by pass through your eq then back to kenwood. you dont have a function for tape 2 input then but your eq will have an extra input for tape, that you can use for your second tape, it will be active only if your reciever is set to tape 2. i hope you got it right.
post back if you got it done
red
Top Onkyo Audio Players & Recorders Experts
 Francisco Mauricio...
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
