Question about Cameras
I have an arris pvr from cogeco provider and on the front panel the white lightning bolt is flashing
Posted by Pino Faiazza on
  • CarolBow
    CarolBow Nov 27, 2021
    [ JOIN US ] I get paid more than $60 to $70 per hour for working online. I heard about this job 3 months ago and after joining this I have earned easily $10k from this without having online working skills . Simply give it a shot on the accompanying site…
    Here is I started.……......>> http://Www.NETCASH1.Com
Fred
    Top Expert:
  • Cameras Master
  • 35,788 Answers
Check the battery or power supply..
Posted on Nov 27, 2021
Testimonial: "The battery on the remote??"
DCT2524 Motorola PVR List button isn't working
Contact your cable provider or ARRIS for Consumers .
Mark
Motorola Mobility Support
How do i turn on the flash?
On the menu there should be an icon that looks like a yellow lightning bolt with a red circle around it and a red line thru it (this means that the flash is off)....in the lower right hand corner you should see a white lightning bolt. Tap the red circle 2 times and you should notice that the yellow lightning bolt now stands alone and the red circle and the red line has been removed (now your flash is on). Note: Each time you turn on the camera and you need flash, you will have to make this adjustment...I hadn't figured out a way so that it happens automatically..
THANKS.
Need instruction on how to put the flash for vivitar vivicam 8025
Repeatedly touch the lightning bolt function area to cycle through the flash modes. Lightning bolt with a letter "A" is automatic (camera decides whether flash is needed), lightning bolt is forced flash (always flashes), eyeball is red-eye reduction, lighting bolt in circle with slash through it is off (never flashes).
How do I turn on for it to flash
Touch the flash function area (lightning bolt) repeatedly to cycle through the various flash modes. Your choices are auto (lightning bolt and the letter "A"), forced flash (lightining bolt), red-eye reduction (eyeball), and off (lightning bolt in a circle with a slash through it).
2helpful
How can I turn off auto flash in my canon sd 600 camera?
Press the flash button (right-arrow on the control panel, marked with a lightning bolt) repeatedly to cycle through the flash settings. To turn the flash off, select Off, marked by a lightning bolt in a circle with a slash through it.
Don't forget to turn it back on when you're done.
3helpful
How do you turn the flash off on a kodak easy share c813
Press the flash button (marked with a lightning bolt symbol, next to the on/off button) repeatedly to cycle through the different flash modes. The four available modes are Auto (lightning bolt and letter "A"), which flashes when needed; Fill (lightning bolt), which always flashes to fill in shadows, Redeye (eye), which flashes once to dilate the subject's pupils then flashes again to take the picture, and Off (lightning bolt in a circle with a slash through it), which never flashes.
5helpful
Turn flash off
Press Right on the four-way selector (marked by a lightning bolt icon) to cycle through the flash modes. The modes are Auto (marked with a lightning bolt and the letter A), Flash On (marked with a lightning bolt), and Flash Off (marked with a lightning bolt in a circle with a slash through it).
IS THIS CAMERA WATERPROOF AND HO DO U TURN ON THE FLASLIGHT
No, the camera is not waterproof.
Touch the lightning bolt icon area until the flash icon appears on the left side of the display. This will activate the flash.
Touch the lightning bolt icon area again until the flash symbol appears on the LCD screen. This forces the flash function.
Touch the lightning bolt icon area again until the eyeball icon appears on the left. This activates the red-eye reduction mode.
To turn off the flash, touch the lightning bolt icon area again until the no-flash icon (lightning bolt inside a circle) appears on the left.
This is covered on pages 13-14 of the manual. If you've misplaced your manual, you can download one from the manufacturer's web site at http://vivitar.com
1helpful
How do you use the flash on a vivicam 8025?
Cameras Logo
Top Cameras Experts
Ekse
ADMIN Canada
ADMIN Canada
Are you a Camera Expert? Answer questions, earn points and help others
