I have VHF Standard Horizon GX5500S and at screen have a message "EE-PROM ERROR"
Good day to all, I have VHF Standard Horizon GX5500S and at screen have a message "EE-PROM ERROR" cant use any knob or any butons, is totally out of order and not working. Please what does mean ?
Fred
    Top Expert:
  • Televison & ... Master
  • 35,491 Answers
The EE-Rom has lost its programme or failed. Could be due to incorrect or broken update.
Return it to the manufacturer for service.
Posted on Nov 25, 2021
Standard Horizon vhf stuck at screen message "EE-PROM initializing"
It sounds as if the radio needs to be reprogrammed. It could also be a cold solder joint causing the problem but my guess is the radio needs to be reprogrammed. If you purchased this used, it is very likely that the frequencies were removed prior to the sale. OR, the EEPROM was removed to make surre that the frequencies were removed. It's typical practice for radio shops to do this to prevent unauthorized use on radio frequencies.
How do I reset my MMSI number on my Standard Horizon HX751 hand held unit.
You cant. Contact previous owner and ask for mmsi transfer or contact manufacturer about how to program new mmsi number.
1helpful
How do I connect my Garmin GPSMAP 451 to a Standard Horizon GX1200E VHF radio, eclipse DSC?
Hi
You'll need to identify and connect NMEA out (+ and -) from your 451 to NMEA in (+ and -) to your VHF to get it done.
Hope this is helpful.
-Steve
I have a standard horizon hx280s it sayes busy all the time cant get out
Remove the battery. Re-insert the battery. Does it still show BUSY?
It sayes busy all the time standard horizon hx280s vhf
It sounds like you have CTCSS squelch activated and that the manual quelch control is fully open. Try adjusting the manual squelch. My quess is that the "BUSY" indication drops, and you will then be able to scan, etc.
Integrating AIS, Radar, Autohelm 7000 and flux gate compass.
ActiSense makes a programmable multiplexer that should do this for you. It is called an ActiSense NDC4 USB. Not sure is the Standard requires a separate compass signal, but if not, and the Standard can use a standard 38000 baud AIS data stream, the NDC4 will work for you. 847-746-0100
http://www.blueheronmarine.com/Actisense-NDC-4-USB-NMEA-0183-Multiplexer-with-USB-Port-6334
Standard horizon 155c not acquiring signal
If the signal is good statement seems to imply that it is working, perhaps this is my misinterpretation of what you mean by this.
Signal refers to the abi;ity to connect to satellites
4 are requied for triangulation.
If the unit is fully charged and not connecting , then it is quite possible that the unit has a damaged SIIRF chip or whatever chip was used in your model to acquire satellite connection. The cost of repair is costly, it means total replacement of the M/Board.
Never start car with the unit connected into DC car power, spikes will damage the chip
1helpful
I am trying to delete all tracks/routes on CP180 Standard Horizon
reading your owners manual (link provided at below) , i see you can delete / edit points one at a time or a faster way format the C Card.
** formatting the c card instructions >
1.) press MENU , move the shuttle point knob to highlight USER POINTS , and press ENT .
2.) move the shuttle point knob to highlight USER C CARD, and press ENT .
3.) move the shuttle point knob to highlight FORMAT ,
and press ENT .
4.) a popup warning window will pop up to confirm you want to format the user C card .
5.) select YES , and press ENT to confirm , (select NO otherwise) .
NOTE : formatting the user c card erases all files previously saved on the c card .
CP180 users guide
J5
Pixels
Good Day, There is a device that can be used to correct your concerns. Symptoms can be correct by EE PROM CORRECTION TOOL:
LSUQ0100. Instructions included. Try calling 1-800-458-6053. It's under $100.00 and takes about 1 hour from start to finish. Good Luck, big IRISH.
Open Questions:
Televison & Video Logo
Top Televison & Video Experts
Ekse
