Heater won t stay lite release button dies out
Where to buy thermo copler
Posted by Kenneth Kolanowski on
ADMIN Canada
    Top Expert:
  • Heating & Co... Master
  • 41,552 Answers
Google
make model replacement thermocouple
NOTE: that it is NOT a 'thermo coupler', one word, 'thermocouple'.
You can also make sure the pilot just is clean and giving a good flame. Also make sure the hood over the flame hasn't moved or dropped off.
Please always include FULL 'make model (what it is)' in all questions. It really helps us to provide better, and more accurate answers Kenneth.
Posted on Nov 25, 2021
ray gallant
    Top Expert:
  • 73,782 Answers
MANY THINGS CAN ONLY BE OBTAINED THRU A LOCAL DEALER OF THE BRAND IN QUESTION
1helpful
My fireplace pilot lite wont stay lite
There is a valve which you are bypassing when you press the pilot button. It is usually a sealed hydralic valve which holds the gas on as long as a flame is on the bulb. This expands the fluid and keeps the gas valve open. If the bulb moved and is not in the flame, or near enough, it will not stay on. Also since it sat for a year the internal workings of the valve could have "gummed" up. You need to replace the valve. You did not mention the name or model of the unit. Do a search with your units brand name followed by heater followed by parts. This should return dealers who can supply the part you need. Let me know if you need anymore help.
hardrocko
Thanks for using FixYa
6helpful
Cant get my heater to stay ignited
THERMO COUPLER, COPPER PEICE INSIDE TUBE MAKE SURE THE FLAME IS IN CONTACT WITH THIS PEICE, 99 PERCENT OF THE TIME IF A UNIT HEATER, WATER HEATER ETC WILL NOT STAY ON AND DOES WHEN YOU HOLD IT IN IT IS THE THERMO COUPLER
4helpful
2answers
Laars Lite 2 LG - pilot light will not stay lit. As long as you hold down the pilot light once it is lit it stays lit but when I turn the nob to the "on" position (release the pilot light button) the flame...
It sounds like a thermocouple has gone bad. this is a very common problem with gas powered things ie; water heaters, furnaces, hot tubs. The telltale sign is when you release the pilot light button it won't stay lit. This is a safety feature and is relatively inexpensive and easy to repair.
One year old heater
Try to hold the button down for 30 seconds at least before turning the knob to ON.
If you are doing this and it still goes out after you let up on the knob, then it may needs a new flame sensor.
2helpful
Pilot lite will not stay lite
You need to change the thermocouple on the unit.
First check to see if the flame is hitting the thermocouple when the flame is on when you hold down the button. If it is then remove the the thermocouple and replace with the same size. You should be able to pick one up at your local hardware store.
If when you replace the thermocouple the flame does not stay lit still you may have a bad gas valve.
Hope this helps and please rate this!
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
john h
