Battery wont charge - alarm sounds
Suddenly alarm sounded - power OK into main circuit board
Posted by Charles Houston... on
Aron
  • Televison & ... Master
  • 2,040 Answers
The battery cold be faulty and needs to be replaced.Or that you guys have a bad battery then. that is no longer charging anymore.
Posted on Nov 25, 2021
MY SAMSUNG S6 HAS SUDDENLY STOPPED CHARGING WHEN i PLUG IT INTO THE ELECTRIC PLUG, BUT IF i PLUG IT INTO MY COMPUTER THEN IT CHARGES, IT NOT THE LITTLE PLUG AS I TRIED MY FRIENDS ALSO WONT CHARGE
Sounds like a faulty AC - DC power pack . Other possibility is you have no AC power to power point . Either from a surge protected power board that has gone into protection or a blown fuse or circuit breaker to ac power point . Suggest try plugging in another device like a lamp to see if power point is ok or try another power point in house to rule out a faulty power point ..
My Panasonic Viera 32" DV3 has suddenly lost picture but sound remains. Connected to Sky HD which appears to be working as channels change with remote and red light for recording is on but no picture
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board..
The TV suddenly started to malfunction. There is a 'pop' sound followed by the screen turning cloudy or misty, the sound and functions are ok. The tv returns back to normal in about an hour.
Flat battery. Recharging but why is fuse board making lot of clicking noises and sounding alarm as battery charges?
1st disconnect the battery from the circuit board and charge the battery separately. Then reconnect the battery and see if it resets itself normally.
1helpful
HP TouchSmart tx2 wont charge or start
Most likely the power jack has gone bad. This happens regularly on laptops. Some laptops have a replaceable circuit board with the jack but most are soldered directly to the main board. If separate board, most cost under $50 and jacks themselves are usually under $10. Either way you have to have the skills necessary to take the laptop apart and soldering skills if it does not use a replaceable board.
Wierd alarm sounds at irregular intervals, the computor seems ok but the alarm is loud and lasts for about one minute
This could be related to your main battery, if the charge is to low it will emit alarm. Pull the main battery out and run it with the power supply to see if that will solve your problem.
Hello! I'm from Riyadh Saudi Arabia. I've left on my Tripp Lite UPS 1000 just last night. When I came in my office in the morning, my desktop computer including my computer server was OFF. I supprised that...
Unplug the computer. Then run the UPS self-test and the unit will display whether it finds an overload fault, whether the battery needs to be charged or replaced.
Here are the instructions (copied from the User Manual):
Turn UPS on: Press and hold the ON/OFF button for one second.
Run a Self-Test: Press and hold the MUTE/TEST button for two seconds (until alarm beeps several times).
The test will last 10 seconds. All LCD Display icons will be illuminated and the alarm will sound.
If the fault icon remains lit, the battery-supplied outlets are overloaded. Unplug powered devices until you remove the overload.
If the "Replace" icon remains lit and alarm continues to sound, the UPS batteries need to be recharged or replaced. Allow UPS to charge for 24 hours and repeat self-test.
Dell inspiron 2200 green LED battery Indicator flashing
sounds like your charging circuit isn't working or the adapter isn't putting out enough power or amprage to fully charge the battery, or you battery went bad. if the charging circuit is bad then so is *********** board, time to burry the system and buy a new one
Works off mains and battery but wont charge battery.
replaced the circuit board where it meets the battery
Open Questions:
Televison & Video Logo
Top Televison & Video Experts
Ekse
