Question about The Computers & Internet
Canoscan 8600f suddenly won't scan
The light comes on but it doesn't move down the page to scan it. I've tried turning on and off, restarting computer, using different USB port but can't get it to work
AnnaLees
    Welcome Back:
    Visited the website for 2 consecutive days.
I get paid over $87 per hour working from home with 2 kids at home. I never thought I'd be able to do it but my best friend earns over 10k a month doing this and she convinced me to try. The potential with this is endless. Here's what I've been doing... http://www.webcash1.com
Posted on Nov 25, 2021
MaryMcCully
A few months ago . I was like a Beggar asking everyone for money and shelter, but a really nice man introduced me to the best on-line work . This work needs no special skills . Now I am able to earn $406/day and $12k/month easy and non-stoppable money . It helps lots financially .Everybody must try this by just using the info on this page......... https://bit.ly/CreditCash1
Posted on Nov 24, 2021
1helpful
My textbook 7p won't turn on
This tablet does t reset with the power button unlike other Android devices. When you hold down the on/off switch, it only drains the battery. If you see the color indicator still charging, allow a full charge.Then, only stay put and pulse the button for a moment quick and let it rest few seconds to try again and again. Only when u see a light coming out of the screen, and I recommend you do this with the power cord on, you hold the power switch down until the rebooting is iniciated. Let go til it is finish and see where the problem is. More likely, like mine, the Settings stop working and needs tune up for the CPU. Never leave an application running when closing your system. With or without internet connection.
G62 won't boot up
Take out the battery and wait a minute, then put it back and try again.
Infocus screenplay 5700 I've had this product for
Hi!
Just had the same problem and I want to sincerely thanks rey francis basa !
I went down and changed C16 as you said. Exactly where you said.
Works perfectly now!
2004 mazda mpv engine racing and cooling fan not working
coolant temp sensor tells the computer how hot or cold the engine is so it can regulate the idle and fuel mixture, when it fails there usually is no cooling fan and you will have trouble starting the engine and keeping it running.
Won't scan, light doesn't come on
Make sure the printer can copy (without computer). If you can make copies, the problem may be the computer or the USB cable. If the printer does not copy also. The problem is in the scanner or in the flat cable.
2helpful
All of a sudden the MP560 won't turn on. The outlet is working but the printer doesn't respond to the ON button. I've checked the power cord it seems to be ok, the cord hasn't moved or been...
This may be a longshot, but many electronic devices like TVs, dryers with electronic computerized controls, entertainment systems like the Wii, and other devices sometimes get "confused" and won't turn on, turn off, or otherwise work properly, perhaps due to a small power surge in your AC line.
I've found that one of the first things to try when it appears to be a failure of the electronics and not a mechanical issue is to unplug the device at the wall (to make sure that any power adapter is also unplugged) and wait about 10 minutes for any residual electric charge to dissipate. Then plug the device back in and give it a try. This has worked with a television, a Wii console, an electric clothes dryer, and some other devices that I thought had died for good. This may explain why sometimes a device is taken to a repair shop and it works fine.
There are, of course, other reasons that the unit won't turn on, but I would try this first before looking for other reasons for the problem.
2answers
My Belkin F5D8236-4 v3 Router won't turn on. We had a storm last night and the power went out but the router won't turn on. I have tried to plug it into different outlets to see if that would work...
Try resetting the router. There should be a little hole somewhere on it with a button inside that you can press with a paperclip. Try holding that button down while you unplug then plug the router in while holding it (if possible). If that doesn't work, I'd suspect the storm might've damaged the router somehow. Was it plugged into a surge protector, and/or have you noticed any other issues with anything else that was turned on at the time?
1helpful
My Dell V505 printer won't print documents from the computer, when I press print the printer prints a page of dash's and ticks. there is ink in the cartridges. i've disconnected the power....
Turn the printer off.
Disconnect the AC power.
On your computer, click Start
Click Control Panel
Click Printers
Select the Dell Printer
Uninstall it
Restart your computer
Turn the printer on
Allow the computer to reinstall the device-device for the printer.
Print a test page.
Scans are taking a long time to scan.
1) Your scanning image resolution may be too higher set 300 dpi / 400 dpi / 600 dpi. Scanning now fast.... not ok look step 2
2) Re-Install Scanner driver / down load new driver. not ok look step 3
2) Replace USB cable.
I have a CanoScan 8600F. When I want to scan I get the not enough space on the target disk
This seems to happen quite often with the Canon scanners. If you know you have enough space on your hard drive, open the CanoScan Toolbox, then click on Settings and change the folder where the temporary files are stored to another folder of your choice, or create a new one in your documents.
Computers & Internet Logo
Top The Computers & Internet Experts
Mohamed Alazhary
Mohamed Alazhary
EKASYS IT SERVICES
EKASYS IT SERVICES
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
