Question about Cell Phones
2007 Jeep Gran Cherokee 3.7l gas 4x4 need the location of the "fuel shutoff valve" Is it near the fuel pump or within the cab?
Showing code P0007
Posted by Don Powers on
  • CarolBow
    CarolBow Nov 27, 2021
    [ JOIN US ] I get paid more than $60 to $70 per hour for working online. I heard about this job 3 months ago and after joining this I have earned easily $10k from this without having online working skills . Simply give it a shot on the accompanying site…
    Here is I started.……......>> http://Www.NETCASH1.Com
brian williams
    Genius:
  • 1,959 Answers
Just remove fuel pump relay
Posted on Nov 24, 2021
john h
    Top Expert:
  • Cell Phones Master
  • 25,745 Answers
No fuel shut off valve
3answers
Error code p0007 on my 2005 dodge durango. Won't start just cranks over and over never fires up
The "Fuel Shutoff Valve "A" Control Circuit High" indicates the problem may lie in the electrical circuit in the fuel shutoff valve control.
My gas guage does not work how do i fix it
Hi Paula,your fuel pump needs replacing,your sending unit is included in pump,here's a link to a new one,have you already fixed it,if so,am i right. http://www.autozone.com/external-engine/fuel-pump/flo-tech-fuel-pump/jeep/grand-cherokee-4wd/1998/8-cylinders-y-5-2l-mfi/700193_591705_0
2helpful
2answers
What does fault code P0007 mean for Dodge Nitro
That code thrown up on generic DTC definitions is "Fuel Shutoff Valve. A Control Circuit Open."
The fix???
No voltage fuel pump or low voltage
it may be the auto shutoff relay has bad contacts in it.. may need it replaced.. bad comes to worse would you consider a bed mounted tank? sits behind the cab/
4helpful
2answers
Where is the fuel filter located?????
In the gas tank, basicly a strainer on the bottom of the fuel pump module.
Is the check valve part of the fuel pump for the 1998 Jeep cherokee?
if you're referring to the one-way valve that prevents backtracking of gas pressure, that's usually located in the fuel pressure regulator
2helpful
Do these Cherokees has a fuel pump emergency/accident shutoff switch? If they do, where is it located and how do you reset it. My cherokee turns over but won't start. Fuel pump has been replaced, no help....
No impact sensor there.
What you may want to test is the Crank Positon Sensor on the bellhousing left (drever) side at about 11o'clock, even with the flywheel. If no signal is coming from there, the asd relay (via the computer) will not allow the injectors to open.
Also test the asd relay and one for the fuel pump as well.
Both relays are in the power distribution center near the battery, test procedures are listed in both chilton and haynes manuals. If you can, use chilton as their wiring diagrams are less generic and more precise than haynes.
2007 1/2 silverado crew cab 4x4 long bed
Need to know if you have a lift kit and what your gear ratio is it says 2000 silerado crew cab 4x4 long bed but is listed in 2000 jeep grand cherokee and need to know your size of rims and what you plan of driving on.
1988 jeep cherokee 4x4 4.0L ruff ideal/no power
try and repalce the fuel pump it sounds like it s getting weak
Cell Phones Logo
Top Cell Phones Experts
Ekse
ADMIN Canada
ADMIN Canada
Are you a Cell Phone Expert? Answer questions, earn points and help others
